- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK50 Switching AP mode then no internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I login Orbi admin then misstakenly switch it to AP mode, then the internet is down. And couldn't connect to Orbi wifi and the login web to switch it back.
was following this youtube: https://www.youtube.com/watch?v=H7LOcJ8GdDo&t=3s
How to reset it? thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK50 Switching AP mode then no internet
@johnny0206 wrote:I login Orbi admin then misstakenly switch it to AP mode, then the internet is down. And couldn't connect to Orbi wifi and the login web to switch it back.
If you switched your Orbi to AP mode before switching your router, you now have no DHCP server.
You can plug into the Orbi router and log in and change it back to router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Press the reset button on the RBR for 15 seconds then release. Wire connect a PC or laptop to the RBR and use a web browser to walk thru the setup wizard.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you ever get this solved. I just did the same thing and can't figure out how to change it back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
If your trying to get to the RBRs web page in AP mode, look at the host routers connected clients list to see if the RBR is listed there, if it is, use the IP address you see there to access the RBRs web page in AP mode.
@AmyManch wrote:Did you ever get this solved. I just did the same thing and can't figure out how to change it back.
