- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR40 VERY SLOW WITH BOTH ETHERNET AND WIFI
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
My Orbi RBR40 is operating very slow.
I have a 1GBS Fiber connection so I get 700-800 MBS both upload and download from the line in.
Through the router and ethernet to my pc, I am getting speeds in the 20-40 Gbs range download and 60-80 upload
Wifi is approximately the same speed
All of my firmware is updated and am running V2.5.1.22
This is terrible speeds, if I can only get this speed from this system, I am wasting my money on the 1Gbs service.
This system used to get ethernet speeds of 600-700 mbs download and upload and WIFI in the 250-300 range which was acceptable to me for wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi RBR40 VERY SLOW WITH BOTH ETHERNET AND WIFI
When did you notice the slow down?
modem?
was the Orbi firmware recently updated?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What gateway are you connected to?
Make sure to have access controls, qos, parental controls, traffic monitoring all disabled. If they were enabled, disable and reboot the router.
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Noticed the slowdown at the beginning of December
no modem, only cat 5 coming in from the router
Router is the Orbi.
It is definitely the router, because i direct connected the cat 5 to my pc and got over 800 download speed
firmware update not recently, I am however running the most current version of the firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
None of that was enabled, and I did disconnect the power for 5 min and let the router reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
ISP is LUSFiber
Gateway is the Orbi Router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You're actually not on the most recent. Not saying the version you're on is bad but the most current is 2.6.1.36
Orbi RBK40 | WiFi System | NETGEAR Support
And that fibre connects to some type of ONT. Do you know what ont/gateway it is?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
How do I upgrade to the most recent firmware.
And, no I am sorry, I am not an IT expert, I do not know what an ont/gateway is.
What I know is LUS has a fiber J-box installed outside and from there Cat 5 to my office.
Cat 5 is connected to the internet input on the Orbi, then i have Cat 5 outputs to a television, Alarm router and PC.
Everything else is wifi from orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You can manually update.
How do I manually upgrade firmware on my Orbi router using orbilogin.com? | Answer | NETGEAR Support
when did it start slowing down?
Were you able to hit full speeds on the orbi prior?
how are you speedtesting? wired? wireless?
What site and device are you testing on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
when did it start slowing down? I noticed it getting worse in early December
Were you able to hit full speeds on the orbi prior? - Yes, ethernet connected would get 7-800 Mbs and WIFI in the 300 mbs range
how are you speedtesting? wired? wireless? both
What site and device are you testing on? Macbook pro for the ethernet connected pc and typically use Speedtest.net site. Wifi using a dell PC sitting withing 10 inches of the router and i used multiple speed test sites. I have also done speed tests with my iphone for the wifi using the speedtest app and the results are all similar.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
did you try the updating the firmware option?
sometimes a factory reset after the update helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have not done a manual update of the firmware. Reading your responses above, i got the impression that my firmware was an acceptable version and the release notes only discussed fixes to security issues. If you recommend that i update, i can certainly do that.
And after the update, I will do a factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I did update it through the iphone app.
I did not update via the procedure in one of the previous answeres, I did not go to manual downloads and down load the file like that. I just had the app search for the updates then hit update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@parramp wrote:I did update it through the iphone app.
updating the firmware through the iphone app is considered a 'manual' update.
FYI...according to Netgear (about a year ago), when a firmware contains major security updates, they will auto push. Auto push requires NO action by the user. It can happen over night while you sleep.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ethernet direct into modem I get 470Mbos download - Ethernet or WiFi into the Orbi I get 80 to 90.
I’ve done a factory reset on the orbi but no change.
