cwise
Aug 14, 2019Aspirant
Orbi RBR50 occasionally doesn't route Internet traffic
Fairly frequently my Internet access will stop working whether wireless or wired. Nothing will load, though whatever device I'm on shows I'm still connected to the local network and can access the Orbi via the app and the admin web page. The Orbi itself apparently still has Internet access, because it reports a connected/online status and it will successfully execute a speed test, but it's not sharing that connection with anything on the LAN side. This might happen several times a day, or not quite every day (unless it happens at a time I don't notice). It may resolve itself within 30 minutes, but it could continue hours later. Seems like sometimes it resolves right after I run a speed test from the Orbi app. When that doesn't resolve it, rebooting the Orbi seems to do the trick. This is frustrating to troubleshoot because I can't intentionally cause the issue, I haven't found a solution that always works (except rebooting), and I haven't identified any pattern to when it occurs or when it resolves itself.
Don't think I have a double NAT situation. My cable modem is just a modem, and the Orbi's WAN IP is a public one.
There shouldn't be anything else on the LAN that could be inappropriately issuing DHCP leases, plus all the devices on the LAN lose or regain Internet connectivity at the same time.
Nothing stands out to me in the Orbi logs, just DHCP renewals, NTP syncs, and DoS attacks that don't seem to correlate with the local outages.
I'm at a loss. Any thoughts?
I have a RBR50 as router and a RBS50, both firmware version 2.3.5.30.
- ekhalilMaster
This can be related to the ISP Lease Time issue:
- When this issue happens, what would you see in the web GUI under >> ADVANCED >> ADVANCED Home >> INTERNET PORT >> CONNECTION STATUS. What are the values for “Lease Obtained” and “Lease Expires”?
- Will disconnecting the internet cable from Orbi’s WAN port and connecting it again resolve the issue?
- cwiseAspirantRight now (though I am not currently having the issue) I see Lease Obtained 0d 8h 0m and Lease Expires about 5h, which would make sense since I rebooted about 3h ago.
I will report back when I have the issue again. Thanks for your really quick response.
What is the Mfr and model# of the ISP modem?
cwise wrote:Fairly frequently my Internet access will stop working whether wireless or wired. Nothing will load, though whatever device I'm on shows I'm still connected to the local network and can access the Orbi via the app and the admin web page. The Orbi itself apparently still has Internet access, because it reports a connected/online status and it will successfully execute a speed test, but it's not sharing that connection with anything on the LAN side. This might happen several times a day, or not quite every day (unless it happens at a time I don't notice). It may resolve itself within 30 minutes, but it could continue hours later. Seems like sometimes it resolves right after I run a speed test from the Orbi app. When that doesn't resolve it, rebooting the Orbi seems to do the trick. This is frustrating to troubleshoot because I can't intentionally cause the issue, I haven't found a solution that always works (except rebooting), and I haven't identified any pattern to when it occurs or when it resolves itself.
I have a RBR50 as router and a RBS50, both firmware version 2.3.5.30.- cwiseAspirantMy ISP modem is an Arris TM1602A.
I have not performed a factory reset on the Orbi
since I set it up a couple months ago. I think there have been two firmware updates since then. Is it considered good practice to do that after every FW update?- FURRYe38Guru - Experienced User
If you run into odd issue, yes, a reset and setup from scratch maybe needed. After the reset, I would set the default DHCP IP address pool size to 192.168.1.100 thru .200.
I would power OFF the iSP modem for 1 minute while the Factory reset happens on the RBR. Then walk thru the setup wizard on the RBR.
