Orbi WiFi 7 RBE973
Reply
Orbi RBR50 won't let me click links
gwkhiatt
Tutor
WHen on my Orbi signal, i often can't click a direct link. It asks me for a security code for the website.  If I use my signal from ATT on the same page it works fine.  I'm a novice at this. Please help.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 7
Guru
Re: Orbi RBR50 won't let me click links
What broswer are you using? Try a different browser? IE11, Firefox or Opera.
Do you have Armor or Circle enabled?
Message 2 of 7
gwkhiatt
Tutor
I've attached pictures of the ATT boxes.
I'm going to reveal how much of a novice i am.
Not sure what firmware is but I have a MacBook Pro with latest Catalina.
I've tried google and safari and none of them work.
I thought it was armor at first, but my free trial is expired.
Thanks, G
Message 3 of 7
Guru
Your photo is from Bluecross support card. Not of the ISP modem.
Were looking for ISP modem Manufactuer and model# information.
FW=Firmware on the Orbi system.
Message 4 of 7
gwkhiatt
Tutor
WHOOPS
Message 5 of 7
gwkhiatt
Tutor
Message 6 of 7
Guru
Ok so your ISP modem already has a built in router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
#3 would be easiest configuration to try.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 928 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
