Orbi WiFi 7 RBE973
Reply
Orbi Satellite RBS50v2 - Blinking White Light - Can't Re-Sync or Reset
iScream
"Your complimentary technical support expired on 2020-04-15"
How fitting, that exactly after one year my Orbi RBS50v2 Satellite just died.
Symptoms are:
- Continuous blinking white light
- The power button is solid green
- When plugged into a computer with a cable the ethernet connection seems to fade in and out. (Windows identifies the ethernet connection then loses it)
I tried:
- Resetting the device (Clicking the reset button until the power light blinked orange)
- Long 60 second press on the reset button
- 30-30-30 Reset method
Before I throw the satellite away -- Is there any option left?
Please help!
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 5
CrimpOn
Guru
Re: Orbi Satellite RBS50v2 - Blinking White Light - Can't Re-Sync or Reset
A last resort is to attempt to flash firmware to the satellite using the Trivial File Transfer Protocol (tftp).
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
This is not for the technically shy.  The computer being used to tftp has to be changed to a static IP address for this task and then changed back before reconnecting to the network.  Wiindows has a tftp program in the "Widows Features" which can be activated.  I used the one recommended in one of those articles.
I have done this successfully a couple of times.  Download firmware for the RBS50v2 satellite from the Netgear support site:
https://www.netgear.com/support/product/RBS50v2.aspx#download
Choose the firmware version that matches the router firmware. (The "+" sign displays all versions of firmware that are available.)
Unpack the zip file to extract the *.img file for the satellite.
I have found that tftp is touchy.  There is a brief window of time after a unit is powered up when it looks for a tftp connection.  After that, it has moved on to regular startup and no longer accepts tftp.  It has taken me 6-8 attempts to get the magic "file transferring" notice.
Also, I am not entirely clear which IP address the satellite will be at during this brief time.  Cannot remember if it was 192.168.1.1 or 192.168.1.254 or......
Message 2 of 5
Guru
Need to press the reset button for 30 seconds then release, then use PUT on the TFTP app to upload the FW file.
Message 3 of 5
iScream
UPDATE: Netgears's tech support team granted me a complimentary one-time grace.
Thanks @CrimpOn , I actually tried that with the help of their support team and the satellite could not maintain a stable connection to the PC, and kept resetting.
You could see that the network is being identified/discovered by windows and then continuously discinnected.
As a last resort I have purchased a serial-to-USB cable, disassembled the satellite and will try to hard wire the damn thing and force the firmware through the USB cable.
This is the video that inspired me: https://youtu.be/V-ltOlzC0Hw
This is the cable I've purchased:  https://www.amazon.com/dp/B00QT7LQ88?psc=1&ref=ppx_yo2_dt_b_product_details
I'll keep you posted if it works 🙂
Message 4 of 5
DLynch
What do you change in the TFTP instructions in terms of static IP, subnet mask, etc to use with a satellite vs a router?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1189 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
