Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi / Security Panel
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-12-31
07:00 AM
2016-12-31
07:00 AM
I just bout and Orbi router and satellite. I am not the most technical but can usually find my way around. I have a COR security system that will easily connect to my existing routers. For some reason I can connect the COR system to the ORBI but it does not connect properly. It shoes up on the ORBI app as an unknown system but the panel does not recognize being connected to the network. Any suggestions?
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-12-31
05:21 PM
2016-12-31
05:21 PM
Re: Orbi / Security Panel
Some security systems require a static IP address and port forward for them to work properly. Check with your security system provider.
Rodney
Message 2 of 2
Announcements
