- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Orbi WIFI keeps dropping out???
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi WIFI keeps dropping out???
@thevans4 wrote:
Using Orbi Mesh system router RBK23 for 4 days now. Granted the setup is faster than the old mac extreme system I had throughout the house. But it continually drops signal. So much so my security cameras ar enot even picking everythng up because they continually have to reboot.
I spent 3 hours with tech support- India- they knew nothing how to help.
I can't access http://www.routerlogin.net - to change anything. The remote management on my iphone can't access. Seems like this is a ongoing problem- NET GEAR do somethng about it. Any advise from other users is appreciated. When you ditched the Orbi what did you replace it with?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What firmware version are you running on your orbi system?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modern connected to Router, Orbi in Router mode. Security Cameras are connected to the router- The modern is not shutting off it is the Orbi router that keeps dropping out. At least 2-4 times a day. Sometimes it reboots itself but more often than not you have to manually turn it off and reboot all three. So unreliable. The security cameras are connected to the wifi system so when the router is not functioning neither are the cameras- sometimes I have to manually go and reinstall each one to the network as they don't always automatically reconnect. If I could access the software online I could tell you what firmware I am using. As far as I know it is the latest as it updated when we installed (1 week ago). I am going to try the Google equivalent and see how that goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW version are you using on the router and satelites?
What is the distances between the router and satellites?
How big is your home? Sq Ft?
Any wireless neghbors near by? If so, how many?
What channels are you using?
What is the Mfr and model# of your ISP modem? Buit in router here by chance?
What phone do you have? Apply or Android?
Can you access the Orbi's router page from a PC connected to the router?
How many cameras do you have connected to the router? Mfr and model# of cameras?
My CBK40 is in gatway mode, Zero issues without having to reboot or resets in any time frame. 3 cameras and two NEST controllers connected on mine.
Set up my friends RBK50 a couple of weekends ago in router mode. Zero issues there as well:
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have plenty of empathy for those having issues, it is the childish whining and demanding my money back! that is just foolish.
Every mesh system, EVERY ONE, has issues. Go to their respective forums and read. I have. THEY ALL HAVE ISSUES. It's just this forum seems to have attracted the worst users.
The system works for most. It just does. I will continue to try and help where possible, and refute those that insist that it is the worst system ever.
Yes it is expensive, but if YOU can't get it to work, instead of continuing to complain about it, why not just move one. If you bought the Orbi, you can afford ot buy a different system. Life is to short to be so vindictive and crazy about a freaking router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's not a won't. Its that I have Verizon Fios which brings service to my Fios Router (that I am not charged for) with a coax cable. I have no problems with the router and enjoy having the extra ethernet ports to use on it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let me say this again. I will continue to voice my experiences and opinions as I see fit. Just because YOU don't see them as valid doesn't make it so. This is your not YOUR forum.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi WIFI keeps dropping out???UPDATE
I returned the Orbi I had originally purchased to Amazon, and switched to a Google system.
I have not had one problem with the Google, no dropouts, good speed abd super easy setup.
Phone compatible Wifi app- super easy to use.
Fully recommend.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem is back! I dont know why and what to do about this. Dropping out 5-10 times a day.................................
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded? Have you asked for the new Beta to see if that helps any? https://community.netgear.com/t5/Orbi/Looking-for-a-select-group-of-Orbi-Community-members-that-are/...
What is the Mfr and model# of the IP modem the NG router is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was working flawlessly for 6 months or so so that elminates some of the issues you asked about. I did speak with support and they had me change a few things (channels mainly). I will see how this helps. Thanks for the information
- Mark as New
- Bookmark
- Subscribe
- Permalink
IF all else fails, I would ask support for an RMA. You may have a bad system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Switched this out for a Google mesh and never had a problem since.
- « Previous
- 1
- 2
- Next »
