ejstarky75's avatar
ejstarky75
Orbi Wifi Speed Limit RBK50
I have an Orbi RBK50.  Works great.  However, I recently went to 200Mbps on my internet speed through the cable company.  My Orbi will not go past 100Mbps, my previous speed limit.  The modem/router combo gets the 200 Mbps but the Orbi even after doing a factory reset and fresh install will not go above 100Mbps.  I know it is not the modem as that gets 200Mbps whether wired or wifi.  I even put a brand new Cat 6 cable on it instead of a Cat5 and still only 100Mbps.  I know I can just use the cable company router, but it is not a mesh network.  It is terrible outside.  My Orbi covered the whole block where I live.  Please help.  Thanks.
  • FURRYe38's avatar
    What is the Mfr and model# of the new modem? Just curious.
    Glad the new modem fixed it. Please mark your thread and solved so others will know.
    Enjoy. :smileywink:
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • ejstarky75's avatar
      ejstarky75
      V2.3.5.30 firmware
      Arris DG3450A is the modem/router model. Had Motorola 8600 before but went back to cable and got TIvo.  8600 not Moca capable.
      Home is 1052sq ft.  Have satellite on the second floor not even 30 ft away from main router on 1st floor.  Many neighbors near by as I live in asmall town.  None have Orbi system. I will try changing channels and/or taking them off auto.
      Beamforming, MIMO and WMM already enabled.
      I will have to try the items to disable.
      Thanks for all the help!
  • ejstarky75 wrote:
    ........ My Orbi will not go past 100Mbps, my previous speed limit. ......
    How do you make the test? Can it be that the computer you're making the test with has a Base 100 ethernet adapter?
      ejstarky75
      Any of my laptops, iPad or iPhone get the same results 100Mbps.  I got the 200 Mbs results on all of these devices using the cable company modem/router.
      • FURRYe38's avatar
        If your ISP modem has a built in router, please chose of the one of the posted suggested options to configure the modem for the Orbi router.
