Orbi WiFi 7 RBE973
Reply
Orbi guest network setup
pafjf
Follower
Hi
I am thinking of buying the Negear Orbi (the two pack).  I have an existing Tiligin modem/router that is getting long in the tooth so I am thinking of buying a stand alone modem to use alongside the Orbi.  Any suggestions for the modem (or are they all pretty much the same).  My internet connection is 100mbps.  Any help appreciated.
Thanks
Message 1 of 2
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Orbi guest network setup
Hello pafjf
The CM400 will work for your 100 MBPS connection but if you look to get faster speeds in the future you may want to look at the CM500 CM600 or CM700.
DarrenM
Message 2 of 2
All Replies
DarrenM
Hello pafjf
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2355 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
