Orbi WiFi 7 RBE973
Reply
Orbi - iPhone 7 Plus can't connect
IFlyNavy
I can't for the life of me get my iPhone 7 Plus to connect.  I intially was getting "incorrect password".  I changed the SSID, and then it accepted the password but would never connect.  Other devices, i.e. Surface Pro 4 connects just fine, albeit seems a bit slow but it connects.
I tried resetting my iphone's network settings and that is what caused it to change from "incorrect password" to just a few attempts at connecting but never does.
Does anyone else have this issue with IOS devices, or iPhones?
I can't even evalutate it because it's so horrific.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 4
Accepted Solutions
IFlyNavy
Re: Orbi - iPhone 7 Plus can't connect
I'm an idiot and just figured it out. My current network is a Meraki Network. I had AirMarshall enabled. That was killing any connections to rogue APs, in this case the Orbi. I whitelisted it and I'm good to go. Can't believe I forgot about that security measure. Good news, it works. 😀
Message 4 of 4
All Replies
TheEther
Guru
Do you have any funky characters in your SSID or password?  While technically any printable ASCII character is permitted, it's possible that the Orbi may not accept all of them.  Start with something simple to get things working, like an 8 character alphanumeric password.  If that works, experiment with more complex.
Message 2 of 4
NandoFL
Star
Hello. I have an iPhone 7 Plus.  I have no problem at all connecting to Orbi.
Message 3 of 4
IFlyNavy
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4318 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
