- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi latency peaks every 10s
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I've noticed that pinging the Orbi Router when connected to the satellite shows latency peaking every 10s, and lasts for about 3s.
I'm hoping this isn't to be expected and something that could be fixed/improved by changing a setting or a later firmware update given the pings the rest of the time are pretty decent (and way better than my Powerline used to be!).
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=226.184 ms64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=198.941 ms 64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=8.368 ms 64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=8.117 ms 64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=5.093 ms 64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=7.980 ms 64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=7.061 ms 64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=8.927 ms 64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=7.143 ms 64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=7.072 ms 64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=6.487 ms 64 bytes from 192.168.1.1: icmp_seq=11 ttl=64 time=7.305 ms 64 bytes from 192.168.1.1: icmp_seq=12 ttl=64 time=219.613 ms64 bytes from 192.168.1.1: icmp_seq=13 ttl=64 time=189.920 ms 64 bytes from 192.168.1.1: icmp_seq=14 ttl=64 time=163.318 ms 64 bytes from 192.168.1.1: icmp_seq=15 ttl=64 time=4.781 ms 64 bytes from 192.168.1.1: icmp_seq=16 ttl=64 time=6.972 ms 64 bytes from 192.168.1.1: icmp_seq=17 ttl=64 time=8.442 ms 64 bytes from 192.168.1.1: icmp_seq=18 ttl=64 time=7.766 ms 64 bytes from 192.168.1.1: icmp_seq=19 ttl=64 time=6.369 ms 64 bytes from 192.168.1.1: icmp_seq=20 ttl=64 time=6.157 ms 64 bytes from 192.168.1.1: icmp_seq=21 ttl=64 time=8.370 ms 64 bytes from 192.168.1.1: icmp_seq=22 ttl=64 time=6.842 ms 64 bytes from 192.168.1.1: icmp_seq=23 ttl=64 time=8.006 ms 64 bytes from 192.168.1.1: icmp_seq=24 ttl=64 time=5.929 ms 64 bytes from 192.168.1.1: icmp_seq=25 ttl=64 time=170.300 ms64 bytes from 192.168.1.1: icmp_seq=26 ttl=64 time=146.993 ms 64 bytes from 192.168.1.1: icmp_seq=27 ttl=64 time=123.569 ms 64 bytes from 192.168.1.1: icmp_seq=28 ttl=64 time=7.265 ms 64 bytes from 192.168.1.1: icmp_seq=29 ttl=64 time=7.403 ms 64 bytes from 192.168.1.1: icmp_seq=30 ttl=64 time=8.525 ms 64 bytes from 192.168.1.1: icmp_seq=31 ttl=64 time=10.524 ms 64 bytes from 192.168.1.1: icmp_seq=32 ttl=64 time=8.520 ms 64 bytes from 192.168.1.1: icmp_seq=33 ttl=64 time=9.497 ms 64 bytes from 192.168.1.1: icmp_seq=34 ttl=64 time=9.036 ms 64 bytes from 192.168.1.1: icmp_seq=35 ttl=64 time=7.962 ms 64 bytes from 192.168.1.1: icmp_seq=36 ttl=64 time=8.587 ms 64 bytes from 192.168.1.1: icmp_seq=37 ttl=64 time=9.092 ms 64 bytes from 192.168.1.1: icmp_seq=38 ttl=64 time=139.300 ms64 bytes from 192.168.1.1: icmp_seq=39 ttl=64 time=121.157 ms 64 bytes from 192.168.1.1: icmp_seq=40 ttl=64 time=94.661 ms 64 bytes from 192.168.1.1: icmp_seq=41 ttl=64 time=6.622 ms
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi latency peaks every 10s
I just did a test from my laptop connected to satellite via ethernet, not showing the same and actually very good and stable:
Pinging 192.168.1.1 with 32 bytes of data
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Ping statistics for 192.168.1.1:
Packets: Sent = 60, Received = 60, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 3ms, Average = 2ms
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disconnected ethernet and using Wi-Fi there is a lag at about 26 seconds, but overall not as bad as what you are getting.
Reply from 192.168.1.1: bytes=32 time=4ms TTL=64
Reply from 192.168.1.1: bytes=32 time=5ms TTL=64
Reply from 192.168.1.1: bytes=32 time=7ms TTL=64
Reply from 192.168.1.1: bytes=32 time=6ms TTL=64
Reply from 192.168.1.1: bytes=32 time=31ms TTL=64
Reply from 192.168.1.1: bytes=32 time=46ms TTL=64
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also ran a ping test from my laptop connected to the satellite. My ping results aren't as stable as MarkC1024's, but don't show the huge variation of the OP:
Minimum = 3ms, Maximum = 24ms, Average = 6ms
Let's try to figure out what's going on for the OP:
1. Have you run this same test on multiple clients? That will eliminate a client-specific issue.
2. What else do you have running on your wireless network? What else is connected to the same satellite (Basic... Attached Devices)? I have 9 other clients attached to the same satellite as my laptop, including a Dropcam, so there's a bit of other traffic going on.
3. What connection speed is your client using? My laptop is 5G vs. 2.4G. This doesn'treally tell us anything other than at least I'm connected the best way. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ran via Wi-Fi one more time and this time clean. I'd suspect you have something else going one:
Reply from 192.168.1.1: bytes=32 time=9ms TTL=64
Minimum = 3ms, Maximum = 9ms, Average = 4ms
- Mark as New
- Bookmark
- Subscribe
- Permalink
Agree with Mikey. A bit more info will help. You may have something on your nework that is broadcasting (ARP or other) every 10 seconds. Options are to trace the network to see who the offender is, or take components offline one at a time until you can isolate the source.
- Mark as New
- Bookmark
- Subscribe
- Permalink
pingles,
I am seeing the same thing when connected to a satellite via wifi. Its more noticable if i decrease the ping interval from 1 second to a fraction of a second - in the following example I use an interval of a 10th of a second.
ping -c 1000 192.168.1.1 -i .1
I do NOT see this when connected to router via Wi-Fi - only when talking to Satellite via Wi-Fi. Test was performed using Mid-2012 Retina MacBook Pro running OS X Sierra 10.12.2. My Oribi RBK53 (Costco 3 pack) is running firmware V1.4.0.18
pingles: how many satellites do you have? I have 1 router and 2 satellites.
64 bytes from 192.168.1.1: icmp_seq=451 ttl=64 time=4.997 ms 64 bytes from 192.168.1.1: icmp_seq=452 ttl=64 time=5.568 ms 64 bytes from 192.168.1.1: icmp_seq=453 ttl=64 time=4.252 ms 64 bytes from 192.168.1.1: icmp_seq=454 ttl=64 time=4.796 ms 64 bytes from 192.168.1.1: icmp_seq=455 ttl=64 time=4.808 ms 64 bytes from 192.168.1.1: icmp_seq=456 ttl=64 time=5.918 ms 64 bytes from 192.168.1.1: icmp_seq=457 ttl=64 time=4.896 ms 64 bytes from 192.168.1.1: icmp_seq=458 ttl=64 time=4.875 ms 64 bytes from 192.168.1.1: icmp_seq=459 ttl=64 time=3.767 ms 64 bytes from 192.168.1.1: icmp_seq=460 ttl=64 time=5.479 ms 64 bytes from 192.168.1.1: icmp_seq=461 ttl=64 time=4.147 ms 64 bytes from 192.168.1.1: icmp_seq=462 ttl=64 time=5.974 ms 64 bytes from 192.168.1.1: icmp_seq=463 ttl=64 time=6.681 ms 64 bytes from 192.168.1.1: icmp_seq=464 ttl=64 time=4.803 ms 64 bytes from 192.168.1.1: icmp_seq=465 ttl=64 time=5.929 ms 64 bytes from 192.168.1.1: icmp_seq=466 ttl=64 time=5.216 ms 64 bytes from 192.168.1.1: icmp_seq=467 ttl=64 time=8.082 ms 64 bytes from 192.168.1.1: icmp_seq=468 ttl=64 time=5.430 ms 64 bytes from 192.168.1.1: icmp_seq=469 ttl=64 time=4.777 ms 64 bytes from 192.168.1.1: icmp_seq=470 ttl=64 time=7.027 ms 64 bytes from 192.168.1.1: icmp_seq=471 ttl=64 time=4.805 ms 64 bytes from 192.168.1.1: icmp_seq=472 ttl=64 time=7.067 ms 64 bytes from 192.168.1.1: icmp_seq=473 ttl=64 time=4.367 ms 64 bytes from 192.168.1.1: icmp_seq=474 ttl=64 time=4.655 ms 64 bytes from 192.168.1.1: icmp_seq=475 ttl=64 time=4.671 ms 64 bytes from 192.168.1.1: icmp_seq=476 ttl=64 time=4.624 ms 64 bytes from 192.168.1.1: icmp_seq=477 ttl=64 time=5.801 ms 64 bytes from 192.168.1.1: icmp_seq=478 ttl=64 time=4.724 ms 64 bytes from 192.168.1.1: icmp_seq=479 ttl=64 time=4.095 ms 64 bytes from 192.168.1.1: icmp_seq=480 ttl=64 time=4.839 ms 64 bytes from 192.168.1.1: icmp_seq=481 ttl=64 time=5.581 ms 64 bytes from 192.168.1.1: icmp_seq=482 ttl=64 time=4.024 ms 64 bytes from 192.168.1.1: icmp_seq=483 ttl=64 time=5.493 ms 64 bytes from 192.168.1.1: icmp_seq=484 ttl=64 time=5.539 ms 64 bytes from 192.168.1.1: icmp_seq=485 ttl=64 time=5.540 ms 64 bytes from 192.168.1.1: icmp_seq=486 ttl=64 time=4.102 ms 64 bytes from 192.168.1.1: icmp_seq=487 ttl=64 time=6.181 ms 64 bytes from 192.168.1.1: icmp_seq=488 ttl=64 time=35.406 ms 64 bytes from 192.168.1.1: icmp_seq=489 ttl=64 time=119.046 ms 64 bytes from 192.168.1.1: icmp_seq=490 ttl=64 time=19.870 ms 64 bytes from 192.168.1.1: icmp_seq=491 ttl=64 time=122.219 ms 64 bytes from 192.168.1.1: icmp_seq=492 ttl=64 time=108.944 ms 64 bytes from 192.168.1.1: icmp_seq=493 ttl=64 time=44.019 ms 64 bytes from 192.168.1.1: icmp_seq=494 ttl=64 time=112.745 ms 64 bytes from 192.168.1.1: icmp_seq=495 ttl=64 time=9.956 ms 64 bytes from 192.168.1.1: icmp_seq=496 ttl=64 time=195.285 ms 64 bytes from 192.168.1.1: icmp_seq=497 ttl=64 time=96.414 ms 64 bytes from 192.168.1.1: icmp_seq=498 ttl=64 time=3.949 ms 64 bytes from 192.168.1.1: icmp_seq=499 ttl=64 time=58.528 ms 64 bytes from 192.168.1.1: icmp_seq=500 ttl=64 time=248.221 ms 64 bytes from 192.168.1.1: icmp_seq=501 ttl=64 time=143.193 ms 64 bytes from 192.168.1.1: icmp_seq=502 ttl=64 time=46.081 ms 64 bytes from 192.168.1.1: icmp_seq=503 ttl=64 time=35.972 ms 64 bytes from 192.168.1.1: icmp_seq=504 ttl=64 time=231.457 ms 64 bytes from 192.168.1.1: icmp_seq=505 ttl=64 time=129.308 ms 64 bytes from 192.168.1.1: icmp_seq=506 ttl=64 time=28.345 ms 64 bytes from 192.168.1.1: icmp_seq=507 ttl=64 time=94.077 ms 64 bytes from 192.168.1.1: icmp_seq=508 ttl=64 time=5.232 ms 64 bytes from 192.168.1.1: icmp_seq=509 ttl=64 time=179.847 ms 64 bytes from 192.168.1.1: icmp_seq=510 ttl=64 time=83.300 ms 64 bytes from 192.168.1.1: icmp_seq=511 ttl=64 time=3.749 ms 64 bytes from 192.168.1.1: icmp_seq=512 ttl=64 time=44.362 ms 64 bytes from 192.168.1.1: icmp_seq=513 ttl=64 time=233.889 ms 64 bytes from 192.168.1.1: icmp_seq=514 ttl=64 time=133.388 ms 64 bytes from 192.168.1.1: icmp_seq=515 ttl=64 time=33.705 ms 64 bytes from 192.168.1.1: icmp_seq=516 ttl=64 time=104.128 ms 64 bytes from 192.168.1.1: icmp_seq=517 ttl=64 time=4.008 ms 64 bytes from 192.168.1.1: icmp_seq=518 ttl=64 time=6.274 ms 64 bytes from 192.168.1.1: icmp_seq=519 ttl=64 time=3.883 ms 64 bytes from 192.168.1.1: icmp_seq=520 ttl=64 time=6.042 ms 64 bytes from 192.168.1.1: icmp_seq=521 ttl=64 time=5.978 ms 64 bytes from 192.168.1.1: icmp_seq=522 ttl=64 time=6.475 ms 64 bytes from 192.168.1.1: icmp_seq=523 ttl=64 time=5.549 ms 64 bytes from 192.168.1.1: icmp_seq=524 ttl=64 time=5.455 ms 64 bytes from 192.168.1.1: icmp_seq=525 ttl=64 time=5.751 ms 64 bytes from 192.168.1.1: icmp_seq=526 ttl=64 time=5.832 ms 64 bytes from 192.168.1.1: icmp_seq=527 ttl=64 time=4.702 ms 64 bytes from 192.168.1.1: icmp_seq=528 ttl=64 time=4.082 ms 64 bytes from 192.168.1.1: icmp_seq=529 ttl=64 time=4.590 ms 64 bytes from 192.168.1.1: icmp_seq=530 ttl=64 time=5.860 ms 64 bytes from 192.168.1.1: icmp_seq=531 ttl=64 time=3.874 ms 64 bytes from 192.168.1.1: icmp_seq=532 ttl=64 time=5.861 ms 64 bytes from 192.168.1.1: icmp_seq=533 ttl=64 time=5.321 ms 64 bytes from 192.168.1.1: icmp_seq=534 ttl=64 time=5.039 ms 64 bytes from 192.168.1.1: icmp_seq=535 ttl=64 time=4.444 ms 64 bytes from 192.168.1.1: icmp_seq=536 ttl=64 time=5.166 ms 64 bytes from 192.168.1.1: icmp_seq=537 ttl=64 time=3.715 ms 64 bytes from 192.168.1.1: icmp_seq=538 ttl=64 time=7.307 ms 64 bytes from 192.168.1.1: icmp_seq=539 ttl=64 time=4.303 ms 64 bytes from 192.168.1.1: icmp_seq=540 ttl=64 time=4.320 ms 64 bytes from 192.168.1.1: icmp_seq=541 ttl=64 time=4.574 ms 64 bytes from 192.168.1.1: icmp_seq=542 ttl=64 time=6.064 ms 64 bytes from 192.168.1.1: icmp_seq=543 ttl=64 time=5.582 ms
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see similar when I connect to the Router via wifi also:
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=1.304 ms 64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=1.652 ms 64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=3.817 ms 64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=2.252 ms 64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=4.162 ms 64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=76.322 ms 64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=1.992 ms 64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=96.374 ms 64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=1.776 ms 64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=2.334 ms 64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=4.596 ms 64 bytes from 192.168.1.1: icmp_seq=11 ttl=64 time=2.277 ms 64 bytes from 192.168.1.1: icmp_seq=12 ttl=64 time=9.073 ms 64 bytes from 192.168.1.1: icmp_seq=13 ttl=64 time=1.859 ms 64 bytes from 192.168.1.1: icmp_seq=14 ttl=64 time=19.726 ms 64 bytes from 192.168.1.1: icmp_seq=15 ttl=64 time=1.696 ms 64 bytes from 192.168.1.1: icmp_seq=16 ttl=64 time=4.143 ms 64 bytes from 192.168.1.1: icmp_seq=17 ttl=64 time=12.565 ms 64 bytes from 192.168.1.1: icmp_seq=18 ttl=64 time=37.218 ms 64 bytes from 192.168.1.1: icmp_seq=19 ttl=64 time=107.542 ms 64 bytes from 192.168.1.1: icmp_seq=20 ttl=64 time=62.228 ms 64 bytes from 192.168.1.1: icmp_seq=21 ttl=64 time=2.990 ms 64 bytes from 192.168.1.1: icmp_seq=22 ttl=64 time=0.985 ms 64 bytes from 192.168.1.1: icmp_seq=23 ttl=64 time=2.310 ms 64 bytes from 192.168.1.1: icmp_seq=24 ttl=64 time=1.149 ms 64 bytes from 192.168.1.1: icmp_seq=25 ttl=64 time=2.073 ms 64 bytes from 192.168.1.1: icmp_seq=26 ttl=64 time=1.936 ms 64 bytes from 192.168.1.1: icmp_seq=27 ttl=64 time=3.625 ms 64 bytes from 192.168.1.1: icmp_seq=28 ttl=64 time=2.067 ms 64 bytes from 192.168.1.1: icmp_seq=29 ttl=64 time=2.030 ms 64 bytes from 192.168.1.1: icmp_seq=30 ttl=64 time=4.240 ms 64 bytes from 192.168.1.1: icmp_seq=31 ttl=64 time=2.331 ms 64 bytes from 192.168.1.1: icmp_seq=32 ttl=64 time=77.865 ms 64 bytes from 192.168.1.1: icmp_seq=33 ttl=64 time=25.668 ms 64 bytes from 192.168.1.1: icmp_seq=34 ttl=64 time=1.954 ms
This is from the same MacBook Pro Retina (OSX 10.11.6) as the earlier test. I'll do some more wired/other client tests tomorrow and report back on what I find. Thanks for everyone's help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@pingles wrote:This is from the same MacBook Pro Retina (OSX 10.11.6) as the earlier test. I'll do some more wired/other client tests tomorrow and report back on what I find. Thanks for everyone's help.
I'm starting to wonder if its my Retina MacBook Pro. I noticed that if I have ping going I can make the response times skyrocket by simply clicking on the Wi-Fi icon in system menu bar. Whenever I click the icon I see the same three seconds of high latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also see results like that when connected wirelessly to my Satellite.
On games like league of legends, this shows insane packet loss, rendering it completely unplayable. Connecting to it via ethernet works perfectly.
I have tested this on multiple devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
