- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi network won't connect to the internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
While installing my orbi, in the end the network is established but there is no internet connection. When I disconnected and put my old router (Netgear R6300 Smart WiFi Router) back up to the plate I have internet again. I have DSL from Frontier and the modem I use is a netgear broadband ADSL2+ . I'm sure there is a setting on the modem that I am probably unaware of that needs to be altered. Any advice or ideas ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi network won't connect to the internet
Many ISPs will only hand out 1 IP address. Therefore, try rebooting your modem after you hook up your Orbi to it. As a last resort, have the Orbi clone the MAC address of the R6300.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the assistance. I wound up calling Netgear support and they were able to help me get it connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What did you have to do to make it work?
The answer might help someone who turns up here in the future with the same problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear customer service was very patient and very helpful. Started at www.orbilogin.net . I was trying to do the same thing at www.orbilogin.com, perhaps a "duh" moment on my part. Anyways, they had me select the advanced tab and then run the setup wizard, skipping the firmware update step. Following all the prompts I was able to connect to the internet. Sometimes the simplest thing can trip you up. Afterwards they had me manually download the satellite firmware upgrade via a zip file and then install it. Finally I updated the router firmware via the online option.
