Orbi WiFi 7 RBE973
Reply
Orbi or mesh question(s)
jkimbro
Tutor
Hey all,,, I've got an older DGND4000 and a couple other routers I use just use as "extenders",, but I think it's time to upgrade and I'm thinking maybe to a mesh system.  Currently I have DSL,,, ya,, I know but it's all we can get out here besides satellite.
Anyway, I'm looking at the Orbi,, probably the one before the 6.
Opinions?  And I would need to get a DSL modem,,, correct?  Anything else?
Thanks
Model: DGND4000|N750 Wireless Dual Band Gigabit ADSL2+ Modem Router
Message 1 of 3
SW_
Prodigy
Prodigy
Re: Orbi or mesh question(s)
If DGND4000 is still in good shape, only need to get a new Orbi set.  Just disable the WiFi function in DGND4000, put the Orbi in AP mode, and swap the extenders with Orbi Satellites.
Message 2 of 3
Guru
You might try to bridge the modem as well if it supports this feature. Then you can run Orbi in router mode.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 425 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
