Orbi WiFi 7 RBE973
Reply
Orbi rbk50 90% performance drop over 2-3 days, memory leak?
bariswheel
I found another post, it seems there are hundreds of people reporting symptoms where their 300Mbps connection drops to 30Mbps. Completely unacceptable known issue.
I updated the firmware but I can still reproduce the problem. It's not my cable modem, I have a 500Mbps line that consistently falls back down to 30Mbps.
This is exactly what's happening with my Orbi system. I called their technical support and they attempted to charge me $50 to look into the problem. I've owned this $300 pair for only 18 months, and Orbi cannot own a serious memory leak issue impacting CORE performance, primary problem this product is supposed to solve.
https://www.amazon.com/gp/product/B01K4CZOBS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
This is BBB worthy.
Message 1 of 43
Guru
Re: Orbi rbk50 90% performance drop over 2-3 days, memory leak?
Is this wireless or wired speed testing? Wired is preferred for speed testing?
Compare speed results with different devices?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
What was the last version of FW that was working for you?
Message 2 of 43
bariswheel
No.  Should I and try to repro?
Wireless. Again after a power cycle, no changfes to anything, performance jumps back up to 200Mbps+
Doesn't matter as I already have a control, but sure I suppose I can plug in a laptop if I can find an ethernet adapter, but I can consistently reproduce the issue.
Yes, same results. Ipad and mobile phone also reporty 30Mbps. Google 'memory leak' orbi and you'll notice very similar reports, same issue, many other people reporting identical symptoms.
What is the Mfr and model# of the ISP modem the NG router is connected too? Why does this matter? I don't know right now I can find out later.
Is the Orbi system operating in Router or AP mode? How do I find out?
What is the size of your home? Sq Ft? 2000 sq ft, again doesn't matter as I already get 200Mbps+ results consistenly until I have to power cycle.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. Maybe 20 ft
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. I don't remember.
Any Wifi Neighbors near by? If so, how many? Doesn't matter, I can reproduce problem and experiment in a controlled experiment. But maybe 20 or so.
Ok I'll try all this above thank you.
the latest I downloaded a few weeks ago, the problem was happening before and after the firmware upgrade, so, sadly, the firmware upgrade had NO effect on the symptoms reported. The problme continues to exist.
Message 3 of 43
Guru
Yes please.
Just trying to narrow this down to wifi only if possible. If wired gets good speed constantly, then we can hopefully figure out what wrong with the wifi.
Would like to know if this modem has built in router and wifi or not is all.
Under Advanced Tab/Advanced Setting/Router or AP mode
20 feet is too close between the RBR and RBS. The wifi signal has too much over lap and maybe causing problems.
You maybe in a wifi congested area which also can cause problems such as interference and noise which would contribute to bad wireless behavior. I would try turning down the power output of the RBR from 100% to say 75 or 50% Under Advanced Tab/Advanced Settings.
the latest I downloaded a few weeks ago, the problem was happening before and after the firmware upgrade, so, sadly, the firmware upgrade had NO effect on the symptoms reported. The problme continues to exist. OK
Message 4 of 43
bariswheel
Factory reset is a bit heavy handed, I'd like to eliminate other simple reasons before we nuke and pave here.
I should also note I have 23 clients, with at least 10 sonos devices, but all on 2.4GHz . My iphone, ipad, mac pro, all on 5GHz . The Orbi mobile app consistently shows 500Mbps, so no problems going out to the internet, but the **bleep** Orbi devices are throttling the hell out of my connections to my actual clients. What a lousy product, I'm pretty sure the root cause resolution is a firmware upgrade addressing a memory leak.
Fast.com is showing 10-20 Mbps again. Awful. So much for my business line. I have some other business today but when I have some time to waste on this I'll reply back. Orbi, get your act together and root out these memory leaks, these are serious.
Message 5 of 43
bariswheel
" I would try turning down the power output of the RBR from 100% to say 75 or 50% Under Advanced Tab/Advanced Settings.  "
Helpful advice here. I just knocked it down to 75%, let's see if that increases performance. today.
Ok, so I think that power cycled or did something because now I'm back to what I usually see after a power cycle, 150Mbps . I expect it to go to sh$t back down to 10-15Mbps in a few days.
Under ADVANCED WIRELESS SETTINGS, I also noticed this, none of those were checked. Seems like the first one is a no-brainer, but I''m not putting any checks in anything and changing things one thing at a time.
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
Why would anyone want that disabled? That seems like choosing 'disable good things'.
https://kb.netgear.com/25348/What-is-implicit-beamforming-and-how-do-I-enable-it-or-disable-it-on-my...
Message 6 of 43
bariswheel
Screw it, I also put a checkmark in 'enable implicit beamforming'. The KB article says it's enabled by default, but it was disabled on mine, first time I'm seeing this so now way I turned it off.
Message 7 of 43
dferreira1
Hi,
I'm facing the same issue you have. The only option left for me is resetting the router to factory.
My router is a RBR40, 2.3.5.30 firmware version. I saw other people with same issue with RBR40, but got no solution to it.
A little brief about the issue:
I updated the router, everything went well. After some days I saw my network speed down to 10Mbps (file copying, inside the network wired to wifi ), I noticed that my wireless speed was something between 14mbps and 30Mbps... I rebooted the router and got 866mbps again. After few days (5 or 6 days) the wireless connection dropped to 10-30mbps again.
Message 8 of 43
ekhalil
Master
@bariswheel wrote:
......... I expect it to go to sh$t back down to 10-15Mbps in a few days.
@bariswheel, To me this looks like a build-up of loops in the system.
What type of devices do you have in your Orbi network?
Are your Sonos wired to Orbi? or are they wireless? What other wired devices do you have attached to Orbi?
Message 9 of 43
bariswheel
As expected, a few days later, no difference. We are back to 30Mbps speeds, rebooted the router, and back to 150Mbps+ but expect it to go down again in a few days.
I changed my 5GHz channel to 40 and 2.4GHz to Channel 11, since all my Sonos speakers are on there.
I have at least 10 Speakers on 2.4GHz. But my work is on 5GHz, the only thing on 2.4GHz are my speakers.
Still think this is a memory leak. Fix it Netgear!!!
Message 10 of 43
el-bori
I’m having the same issue. I got a gigabit connection and I only get 50-100 download and 10-25 upload. I reset the router to factory setting a few time too.
Message 11 of 43
ekhalil
Master
Do you use SonosNet? This is used when you have one of the speakers wired and all other speakers wireless.
If not then why are you changing the Orbi channel to 11 which the Sonos is on. Sonos should change the channels according to what you set Orbi to use and NOT the other way around!
Message 12 of 43
Guru
Did the factory reset and setup from scratch resolve your problem then?
@dferreira1 wrote:
Hi,
Message 13 of 43
Guru
A factory reset and setup from scratch needs to be effected before we can place the problem in FW.
Message 14 of 43
bariswheel
Tonight we are at 9.5Mbps on this 500Mbps line. Atrocious. Going to restart every few days.
I'm disappointed I have to factory reset. I will do it when I have an hour or so this weekend.
Message 15 of 43
ekhalil
Master
@bariswheel Not sure if you saw my earlier question: 🙂
Message 16 of 43
Nteck
Tutor
Lots of people- including me-  have same problem with Mobi RBK53. High speed when first you set up. But it only lasts a day. You need to reset to get back to that performance. These so called tech advisers here ( like ekhalil or guru) are either iliterate themselves or think other people are. If I was a manager at Netgear I would have fired them; they are damaging your image. I have followed their advise in other posts. Same things to everybody, and it's not working. Nobody seemed to have fixed the issue doing that - including me! Don't you understand, you have made a crappy product. It has a major problem which can't sudtain the speed.
In my case I got 35mbps from a 1 gig speed service. Speed is right with ethernet at cable modem. I did everything possible recommended including factory reset, etc.
Will return this crap to store tomorrow! a standard router can do way better.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 17 of 43
SW_
Prodigy
Prodigy
@bariswheel , interesting theory about memory leak!
Please point the browser at http://192.168.1.1/debug.htm and verify this theory.  For those who ran into this problem, please check your respective Orbi debug.htm page for memory usage and upload these info here if possible.
Basic Infomation
 	CPU Load	                13.9706%
        Memory Usage(Used/Total)	138MB/495MB
        Flash Usage(Used/Total)	        2945MB/4096MB
        Network Session(Active/Total)	44/65536
Message 18 of 43
SW_
Prodigy
Prodigy
...some folks reported that it's impacting only the Satellite and not main Orbi itself.  If that's the case, please get the debug.htm from the affected Satellites.  Here is an example of my healthy Satellites debug info:
Satellite-1:
Basic Infomation CPU Load 17.2577% Memory Usage(Used/Total) 124MB/495MB Flash Usage(Used/Total) 2945MB/4096MB Satellite-2: Basic Infomation CPU Load 22.2222% Memory Usage(Used/Total) 123MB/495MB Flash Usage(Used/Total) 2945MB/4096MB
Message 19 of 43
SW_
Prodigy
Prodigy
One factor that could negatively impact throughput/speed is high CPU usage.  To monitor Orbi/Satellite CPU usage, please do this:
  1. Enable telnet via debug.htm page
  2. telnet into Orbi
    • telnet 192.168.1.1
  3. type this cmd at the telnet window
    • top
Repeat the same steps and replace Orbi IP address with IP address of the Satellite you want to monitor.  CPU usage should be less 30% and should not anywhere near 100%.
Message 20 of 43
Nteck
Tutor
I will give it this last try later today. I hope that's the case! which seems to be the cause based on your description. Then what is the solution?
Message 21 of 43
Guru
Has a factory reset and setup from scratch been performed since last update?
Message 22 of 43
Guru
Any progress on this?
Message 23 of 43
SW_
Prodigy
Prodigy
It's hard to speculate what the solution is until we can confirm the reason for CPU hog or memory leak.  Assuming that's the case, we could kill the offending process by turning off the associated feature if we could identify it.  Otherwise, we could roll back to a prior FW version that didn't suffer from this problem.
Message 24 of 43
dferreira1
Hey guys, I've got an update on my side...
I could see when I disconnect my MBP or other device and reconnect it, the RX/TX rate came up to 866Mpbs again.
So, I don't know what happenning on router when I disconnect, but disconnecting/reconnect is better than rebooting the router each 3 or 4 days.
I reseted it to factory, reconfigured all the settings again and this issue still happen.
When I see the problem again, will try the telnet solution above to see CPU/memory activity on RBR.
Message 25 of 43
Top Contributors
Discussion stats
  • 42 replies
  • 3977 views
  • 3 kudos
  • 7 in conversation
Announcements
Orbi WiFi 7
