Atmtran's avatar
Atmtran
Orbi rbr40 new printer can’t find the WiFi network
I just brought a new Canon printer TS8370 and the printer can’t search my home WiFi network. Network around my place is able to find. Anyone has any ideas what is the possible issue? Thanks.
  • Yes, different WiFi channels in different countries is one of those things I never think about.  The printer is probably programmed to look for channels 1-11 and you live in a location that allows 12 & 13.  With the Orbi set to "Auto", it could very well see that 12 or 13 has less radio interference and pick one of them.
  • CrimpOn's avatar
    CrimpOn
    Wow, are you ever screwed!  I just spend 20 minutes trying to make sense of the Canon TS8370 User Manual.  I have never seen so much confusing claptrap. http://gdlp01.c-wss.com/gds/6/0300036856/01/TS8300ser_OnlineManual_Win_EN_V01.pdf
    My "guess", and this in ONLY a guess, is that Canon expects the user to configure the printer by
    • Connecting to the printer's own web page (see page 62) which appears to be BJNPSETUP with a smartphone, or
    • Installing their IJ Network Device Utility program which somehow searches for the printer.
    What I had expected to see was directions to open the touch screen on the printer, tap on some sort of "Setup" icon, and follow the directions.
    I sure hope that Canon has some form of user support.
  • FURRYe38's avatar
    Get into a USB to LAN print server device that you can connect the usb printer to.
    • Jetdrive's avatar
      Jetdrive
      Luminary
      Rather that spending more money, I would contact Canon and see if they can help you getting your new printer connected. If they can't, I would suggest returning it and getting another printer that is easier to set up.
  • Thanks guys. I have searched in the community and found ppl with similar problem and resolved by changing the setting of the 2.4GHz channel to ‘11’ rather than ‘auto’ in the Orbi admin pages ("Advanced, 'Setup', Wireless setup'). Then the printer found the WiFi network without a problem. Thanks everyone.
    • CrimpOn's avatar
      CrimpOn
    • FURRYe38's avatar
      Glad you found the fix and it works. Be sure to save off a back up configuration to file for safe keeping.
      Please mark your thread and solved so others will know.
      Enjoy. :smileywink:
