Orbi WiFi 7 RBE973
Reply
Orbi setup and some questions
tmlt0912
Hello,I have some orbi setting and setup questions.(Sorry my English is poor.)
Beacuse iOS disconnection issue,I referenced to https://bit.ly/2CoOybd
and my brother's Samsung is constantly being dropped!
My Orbi setting:
And my setup is correct?Sometimes will happen connection problem...
referenced to https://bit.ly/2ZkDcyZ and https://bit.ly/2tDV9N7
My setup:
Hope everyone can give me advice.
Thanks!
Message 1 of 6
Accepted Solutions
Guru
Re: Orbi setup and some questions
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 6
All Replies
Guru
Message 2 of 6
tmlt0912
V2.3.1.48
DASAN H660WM
I don't know...But router and satellite(s) distance one floor.
2.4Ghz channel is 1,and 5Ghz is 44.
No,only Orbi in my house.
It' enable.
OK,So I will disable Daisy Chain, Fast Roaming, IPv6?
And how to Set 20/40Mhz Coexistence to 40Mhz?I only see "Enable 20/40Mhz Coexistence" chose...
Thank you!
Message 3 of 6
Guru
Let us know how it goes.
Be sure the wifi is disabled on the ISP ONT.
Message 4 of 6
tmlt0912
V2.3.1.48
DASAN H660WM
It' enable.
Thank you!
Yes,It's disabled ont the ISP ONT.
Message 5 of 6
Guru
30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. Placement will be important.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1440 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
