- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi
I am having trouble with loosing bandwidth. My service provider is telling me the issue is from the orbi setup. He led me to look at the channel bands and said we are not using the best channel, but I have no idea how to fix or test or change this. netgear want nothing to do with it. Currently pay for 5mg upload and get 2-3 on speed test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
Be sure to test speeds with a wired PC connected to the RBR for accurate speed results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
how do I know what firmware is there?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? I use Utah Broadband. I called them and they determined signal to house is uninterupted.
I confirmed signal coming intot he house is as it should be, but when it comes thorughthe Orbi I loose about 50% of both upload and download.
I don't know. How do I tell?
I believe the distances are good. The two satelites are on the main floor, and the rbr is in the basement where the wires come in.
I did the diagnostics on my computer and it says I am using current channel count 3, best 2.4 = 11, best 5 is 144, but I have no idea how to change this / test this.
There are about 7 with decent signal, another 7 with almost no signal
I have no idea how to do this.
Sorry - no idea what this is either...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
Do you have a friend, nieghbor or family member who can help you with this?
