- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
@Slothtony wrote:
I have tried everything from power cycling, to factory reseting, the router will not work no matter what I try and do, I tried to talk to netgear representatives and they give me the same thing as online does, the ring light on top of router wont light up it wont turn amber when reset button is held. I dont know what to do
There appears to be confusion over the Orbi "lights". There are two lights on the Orbi: (1) a tiny LED on the back next to the power button, and (2) a "Ring Light" at the top which creates sort of "halo ring" around the top of the case.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
During a Factory Reset, it is the LED on the back that will turn amber and begin to blink: The ring light at the top does nothing during the reset (off)
https://www.youtube.com/watch?v=cMw4ePACgc4
Sometimes it takes longer for the power LED to begin flashing amber than one would expect. There is even a procedure called the "30-30-30" which involves holding the paperclip in the tiny hole for 30 seconds, powering off the Orbi for 30 seconds (while still holding the paperclip), then powering it on again and holding the paperclip for 30 seconds. (Fingers get tired!)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
@Slothtony wrote:
Netgear docis 3.0
That a standard for cable modems, not a Netgear model number.
Here's where to look on the label on the device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
Model:CM1000-100NASSKU:5712202
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
Sounds like the RBR is bad if the top ring does not turn on and start to blink WHITE.
Try a different Power adapter, like the one from the RBS if you have one.
IF the top ring is not turning on at all and blink WHITE afterwards, then the RBR needs to be replaced.
