Orbi WiFi 7 RBE973
Reply
OrbiRbr40 wired speed 400mbps wifi speed 90 mbps
rahuldba
I have rbr40 orbi. Firmware 2.7.3.22.
When I connect lan cable to modem the speed is 400+ mbps. When I check speed in orbi app the max speed it takes is only around 90mbs.
What could be the problem ?
The devices are automatically spread between 2.4 and 5 GHz.
Please help.
Thanks
Rahul
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Guru
Re: OrbiRbr40 wired speed 400mbps wifi speed 90 mbps
Please visit and post about this over in the Orbi AC forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you,.
Message 2 of 4
Guru
Any progress on this?
Please help.
Thanks
Rahul
Message 3 of 4
CrimpOn
Guru
90mbs is a suspicious number because it is 'nearly' 100.  Can you open the Orbi web interface (http://orbilogin.net), log in ("admin" and password), click on the Advanced Tab, then click on the blue "Show Stastics" box.
What does it show for the WAN port? If it shows 100/Full, then the Orbi believes that the modem connection is a 100mb connection rather than a gigabit connection.  That is often because of a fulty ethernet patch cable or a bent pin on the etherent jack.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 580 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
