Orbi WiFi 7 RBE973
Reply
Parental controls
TeriL
Follower
Parental controls
Does the Orbi have parental controls?
Message 1 of 3
CrimpOn
Guru
Re: Parental controls
Netgear has contracted (partnered?) with Disney Circle for parental controls.  There is a community forum devoted to Circle.  If you browse that forum, it will probably give you an idea of what Netgear customers think of the product and whether it is worth the cost. (not free)
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Message 2 of 3
There are two flavours of "parental controls", free parental controls and paid for Circle, which is a more powerful option.
I have seen no indication that Orbi supports parental controls. For Circle check this:
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 495 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
