Orbi WiFi 7 RBE973
Reply
Poor backhaul status after Config Sync
Mjanssen
Guide
Hi,
I'm having difficulties with getting a stable backhaul connection using the RBR40 and 1 RBW30 satelite.
The backhaul status almost all the time shows as "Poor", whatever I try for the location for the satelite (read somewhere that the ideal distance between the router and the satelite is between 12 and 18 m), tried everything from 5m to 20m.
I notice that when I change the 2.4G or 5G channel setting of the wifi, the backhaul status changes to "Good" for a short while. Until the "Config Sync" appears, after which it returns to "Poor". The satelite shows a 5G connection.
Seems to me that after the channel change, the router and the satelite shortly use different channels and after the config sync they use the same. Can it be that the cause interference when using the same channel, which weakens the backhaul connection?
I already disabled 20/40Mhz Coexistence, Daisy-Chain Topology and Fast Roaming and enabled Implicit Beamforming (as suggested in another post in the community), but that doesn't improve anything unfortunately.
Also read that splitting the 2.4G and 5G SSID's can improve the connection, anyone any positive experience with that?
Running firmware V2.3.5.32 on the RBR40 and V2.3.5.6 on the RBW30.
Really looking forward to your ideas and suggestions. I'm convinced that it is a reliable system, but there is something "wrong" somewhere.
With kind regards,
Martijn
Model: RBW30|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 9
Accepted Solutions
Mjanssen
Guide
Re: Poor backhaul status after Config Sync
Hi,
Seems like changing the pre-amble fixed the issue. The backhaul status is GOOD on 5G and the overal wifi experience is a lot better!
Didn't even try the factory reset yet.
Thanks for the tip!
Message 8 of 9
All Replies
Mjanssen
Guide
** UPDATE **
Manually updated the firmware to V2.5.1.16 for the RBR40 and V2.5.0.2 for the RBW30.
No change, behaviour is exactly the same Smiley Sad
Message 2 of 9
Guru
Message 3 of 9
Mjanssen
Guide
Hi @FURRYe38,
Thanks for your response. Saw some of your other posts with some of the same suggestions you mention here. Smiley Wink
The house does have walls between the RBR and the RBW, but not much.
We also unplugged the RBW for a while and most devices were able to connect to the RBR, some with less bars and speed, but still connected.
At first used 2.4G channel on auto, tried 1, 6 and 11. No change.
There are some wifi neighbors, not exactly sure how many (not at the location right now Smiley Wink ), but I was able to find a free 2.4G channel before. Also for 5G.
Armor and Circle are disabled?
Can't set the Set 20/40Mhz Coexistence to 40Mhz only, only disable it completely.
Changed the preamble to short just now, will monitor if any change.
Will do a factory reset when at the location in the near future. Is there a way to save settings? Or is restoring settings not recommended.
Can you explain why the backhaul is good for a short while after any of the wifi settings?
Message 4 of 9
Guru
What is the distance between the RBR and RBW?
When you uncheck the 20/40Mhz box this sets 40Mhz only.
Under Advanced Tab/Advanced Settings/Administration is Backup. You can maybe a back up configuration to file. I would first factory reset the system and setup from scratch and not load any saved config files. Need to first test the system from a clean setup condition first.
Possible there is a RBW problem. Seen others with this modem RBW have problems. I feel the FW on the RBW needs to be updated by NG to be more in line with v16 which is most correct for the Orbi AC line of systems.
Message 5 of 9
Mjanssen
Guide
Tried every distance from 5m and 20m between the RBR and the RBW. Left it at each distance for a couple of hours and monitored the backhaul status.
Will try the factory default option somewhere in the next weeks
The devices are not new. Can it still be updated by NG to get a more stable connection?
Message 6 of 9
Guru
Something to contact NG support and report your experiences.
@Blanca_O
Message 7 of 9
Mjanssen
Guide
Hi,
Thanks for the tip!
Message 8 of 9
Guru
Glad you got it working.
Enjoy. Smiley Wink
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 5925 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
