- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Problems connecting RBS50Y
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to install an RBS50Y Outdoor Orbi as a satellite to my house system.
I successfully set up the RBS50Y - connected to my base station (an RBR40) no problem (Installed as an "Add-on Satellite"
I installed the new RBS50Y in my garage and powered it on. After booting the light shows solid blue suggesting the device is connected to my network. Whilst in the garage I am able to see the RBS50Y on my phones wifi list, and can connect OK - but there is no internet connection.
I checked on my Orbi app - the RBS50Y shows up - indicating there is some connection as it would not be there if powered off - but is not "connected".
I logged onto the router via http://orbilogin.com - and the RBS50Y shows as disconnected. Daisy chain is enabled.
I have three other satellites on my Orbi network - two RBS40's and an RBS20 - all working well.
The RBS20 is indoors and is the closest device to the RBS50Y in my garage (distance around 10 meters / 30ft).
Any suggestions on what might be wrong here - and how I might be able to use my RBS50Y for teh outside wifi it wa smeant to provide
Any and all ideas much appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your suggestions
Tried all of this and got nowhere
Eventually had to go through the pain of a factory reset on my entire system and eventually figured out that the RBS50Y had switched into "range extender" mode rather than default Orbi mode - doing thsi requires some serious effort and I dont think I did it . but hey ho.
Sytem now rebuilt and RBS50Y working OK - although the distance to my garage (plus a couple of solid walls) makes the backhaul connection "poor" on a 2.4GH connection.
Appreciate your suggestions
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Problems connecting RBS50Y
What Firmware version is currently loaded on the RBR and RBSY?
Can you access the RBSYs web page with a PC and web browser?
YOu might turn OFF the other RBS and power cycle the RBSY and see if it gets connected and appears as connected in the RBRs web page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Yes the RBSY works in two different modes.
Please mark your thread as solved so others will know.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@IanPhillips wrote:Sytem now rebuilt and RBS50Y working OK - although the distance to my garage (plus a couple of solid walls) makes the backhaul connection "poor" on a 2.4GH connection.
Might try moving the RBS20 and RBS50Y around a bit. WiFi is really sensitive to obstacles in the direct pathway. I had a "dead spot" that turned out to be because of a brick chimney going up the middle of the house that was casting a huge WiFi "shadow".
Does the Attached Devices display show the satellite connected to the router or to the RBS20?
