- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Problems since switching ISP from Virgin to TalkTalk (UK)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Just switched from Virgin to TalkTalk and now having following issues when connected via Orbi:
- Cisco AnyConnect VPN won't connect
- random 404 errors on some web pages
- Can't download iOS apps
All work fine when connected to TalkTalk wifi so must be an Orbi or Orbi to TalkTalk router problem.
Any and all ideas welcome.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Problems since switching ISP from Virgin to TalkTalk (UK)
What FW is currently loaded?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks for the reply. NG router is on firmware version 2.2.1.210 and TalkTalk router is a Sagemcom FAST 5364 v 3.00.
Looks like Option 3 is the only one from your list that I can get going, though it makes no difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Perhaps not.
The only thing that you changed is your ISP (TalkTalk). Start there.
Also it looks like the Sagemcom FAST 5364 v 3.00 is a Modem/router combo which requires special setup to work with the ORBI ROUTER.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Sorry, should have been clear: ISP changed but also router (comes with the package). Virgin was cable, new router is ADSL.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks for that. How did you discover this / any idea where I can go to find out what is required? TalkTalk are being less than helpful :-(
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
https://www.itwriting.com/blog/10843-talktalks-new-sagemcom-fast-5364-router-and-wifi-hub.html
Looks like you may need to set the Orbi in the AP mode. Many here on this forum can help with that. The Orbi manual should also provide guidance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Does the sagecom modem/router have a DMZ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Don't think so. All looks pretty standard in terms of network settings (DNS, DHCP, routing etc.). I've now established that there's definitely no modem-only mode on the Sagemcom so I might have a go at turning most of the network features/settings off manually and using a static IP on the NG router. Or do the AP-only thing mentioned above. But all of that can wait until tomorrow.
Thanks for all the responses so far - much appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If you can turn OFF items like uPnP, firewall and wifi on the modem, set up a reservation for the Orbi router on the modem, this could help. if not, I presume AP mode will be the best solution. This seems to be a limiting issue with the modem. Too bad DMZ isn't available on the modem.
Have a great evening.
