- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Purple Ring won’t go away
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Purple Ring won’t go away
After the 90 day support ends, Netgear has a support plan called Gearhead https://gearhead.netgear.com/
I have no idea what it costs or if it is "worth it."
You have done the first troubleshooting step: i.e. see if a computer works when plugged into the modem.
The next step is probably to connect the laptop to one of the Orbi LAN ports and access the web interface.
Is the Orbi in router or Access Point (AP) mode?
What is the brand and model of internet modem?
Is the internet modem in "modem only" or in "modem/router" mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem: Netgear CM700. Couldn’t find anywhere to change or identify the ‘mode’ it’s operating in. It does have the latest firmware according to the netgear website.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I trust the web interface more than the app. The Netgear CM700 is an ordinary modem. No router. No WiFi.
When we run out of ideas, the next step is to do a "factory reset" on the Orbi. It is a tedious process, because all of the device reservations have to be entered again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you powered OFF the ISP modem and Orbi RBR for 1 minute, then power on the ISP modem and let it sync, then power on the RBR? You might factory reset the RBR while the ISP modem is coming back online and walk thru the setup wizard. See if the top LED turn off after it's setup.
Swap LAN cables between the ISP modem and RBR to check.
You might do a FW update to v30 as well as a last resort.
@CMcG36 wrote:
Magically 2 weeks after my warranty period my Orbi (RBR50) won’t connect to the internet. I’ve tried rebooting it and resetting it to the factory settings - no change. It’s not my service provider, I can plug my laptop into my modem and it works fine. Is there any way to fix this? How much does phone support cost if I choose to call?
