Reply
QOS on Orbi is it enabled or disabled?
RonV42
Luminary
Ok so I am on the QOS page and there is nothing to say it's enabled or disabled.  Ran the speed test on the page and it shows the resutls but no indication of QOS is turned on or off.   We need a checkbox or somthing here for enableing and disabling.  QOS .png
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 20
Accepted Solutions
Retired_Member
Not applicable
Re: QOS on Orbi is it enabled or disabled?
Worked. The HTML has to be changed to HTM.
Message 18 of 20
All Replies
darkneo29
Star
on my way to buy an Orbi.  Will watch this thread.  Have you tried another browser?  Looks like your missing alot of options as per my R7000
Message 2 of 20
RonV42
Luminary
Yes I logged into it with 4 different browsers:
  • EDGE
  • IE11
  • Firefox
  • Chrome
Same page on all 4...not a browser issue.
Message 3 of 20
when you run the speed test it asks you if you want to set the speed test as the qos on the latest fw , this is then used as auto qos
Message 4 of 20
RonV42
Luminary
It never asks to question to use it just displays the results on the page...I assume it's using it but again there needs to a way to turn off and on.
Message 5 of 20
i think at this stage you would have to factory reset
setting the max qos is a good thing anyway as it stops any one device from hoging the whole bandwidth
Message 6 of 20
RonV42
Luminary
Reset to factory isn't a acceptable solution.  It would be like asking me to replace my car engine after I did maintenance.
Message 7 of 20
darkneo29
Star
Agreed that is crazy.
Message 8 of 20
the qos is still a work in progress , in time it will be like it is on the r8500 etc , just in baby steps
Message 9 of 20
Dan_H
Apprentice
Hey peteytesting, what kind of throughput can we expect with QoS enabled?
Message 10 of 20
dg_sticks
Guide
This is killing me! I believe that the lack of QoS options are holding my LAN speeds back dramatically, but I have no way to verify since I have zero options on the QoS page other than the speedtest. I believe that the factory reset is ridiculous as well. Does anyone have a solution to get the QoS page to show all options?
Message 11 of 20
Dan_H
Apprentice
Have you tried this page, after logging in to the ortbi?
/QOS_main.htm
There are a whole bunch of QoS related directories in there this one looks liek it might help too.
/QOS_Dynamic.htm
Message 12 of 20
RonV42
Luminary
Thanks for the links but until Netgear exposes them from the UI I would be hesitent to try.
Message 13 of 20
Mikey94025
Prodigy
/QOS_main.htm
/QOS_Dynamic.htm
Thanks for these useful QoS links!  Now I can make sure QoS is disabled.
Message 14 of 20
PhoenixV
Apprentice
What are the default settings on these hidden pages supposed to be?
Message 15 of 20
Retired_Member
Not applicable
Dynamic one doesn't seem to exist on mine.
Message 16 of 20
PhoenixV
Apprentice
You have to use the syntax as follows:
/QOS_dynamic.htm
instead of /QOS_Dynamic.htm
Message 17 of 20
Retired_Member
Not applicable
Message 18 of 20
martyfp
Luminary
do any of these hidden QoS pages actually work ?
Message 19 of 20
Retired_Member
Not applicable
Actually, a more accurate analogy would be to reset your ECM after doing maintenance, which is not a bad idea.
Message 20 of 20
Top Contributors
Discussion stats
  • 19 replies
  • 29155 views
  • 17 kudos
  • 10 in conversation
Announcements
