Orbi WiFi 7 RBE973
Reply
RB 50 iPhone App
RB 50 iPhone App
I cannot sign in to the iPhone Orbi app to control my based station and extension.
The sign in page shows "admin" on the User Name line and I cannot edit or change that to my saved user name. So my password will not work with the "admin" user name.
I have restarted the Orbi app and this behavior does not change. I regularly update my iPhone apps and I believe I have the most current version.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 6
Accepted Solutions
Guru
Re: RB 50 iPhone App
Did it work for you? Sometimes the update in iphone doesn't work so the app needs to be fully removed and re-installed again.
Message 4 of 6
All Replies
Guru
Try removing the app from the phone, reboot the phone then re-install the app and try again?
Message 2 of 6
Thanks. That process reminded me of the steps necessary since I hadn't used the iPhone app in some months.
Message 3 of 6
Guru
Message 4 of 6
The deletion, iPhone restart and reload of the app did work. Thanks for the suggestion.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 5 of 6
Guru
Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1458 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
