Orbi WiFi 7 RBE973
Reply
RBK 12 - Satellite light staying solid amber
CFJ
The light of my satellite (placed in my study) stays a permanent solid amber during the last 2 days. The light of the router (placed in the living room) is a solid blue. What should I do to make the satellite light to stay permanent blue? Thank you.
Message 1 of 3
Guru
Re: RBK 12 - Satellite light staying solid amber
Try moving the RBS either closer or farther from the RBR.
Does the RBS appear in the RBRs web status page?
Factory reset the RBR and RBS and setup from scratch an add the RBS again.
Message 2 of 3
CFJ
Thank you for the suggestions. :))
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 615 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
