- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK 33 Connected but cannot go online
- Mark as New
- Bookmark
- Subscribe
- Permalink
We are in an able to get on our Internet even though it says it is connected. With streaming we get it set up that says it has an Internet connection but when we try to get online it says in network error has occurred. We still are unable to either get on our computers or phones. Can anyone please give us some ideas on how to get this back to working.
Djohn47
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK 33 Connected but cannot go online
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Do wired devices get internet access?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Djohn47
Do you have a device wired to the router? If so, can it go online?
I suggest to turn off and on both the modem and router. Kindly make sure as well that you have Internet connection straight from the modem.
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Blanca_O is right: start at the beginning. Do you have a device that can connect with an Ethernet cord (desktop or laptop)? If you do, then the first step is to connect the device directly to the modem and see what happens when you turn it on. It should get an address from the modem and be connected to the Internet. If you do not have something that can be "wired", things get a lot more complicated.
It is probably worth asking how the Orbi was set up to begin with. i.e. using a "wired" device or a smartphone app?
Since you can connect to the WiFi, what does the "Home Screen" say about Internet (i.e. "Good")? On the "Internet" screen just below Home, what IP address does it say was assigned to the Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Poster hasn't been on since posting this...
