- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
RBK13 hooked to a Cox router
I have an Orbi RBK13 hooked to the router provided to us by Cox.
I'm noticing that I still have devices hooking up to the cox router and not the orbi's.
Do I need to shut off the wifi on the Cox router?
TIA
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: RBK13 hooked to a Cox router
Is it a modem/router combo device or just a router?
If its a modem/router combo device, I'd recommend disabling the router part entirely. (hint, disabling wifi doesn't disable the router portion) Contact the ISP for help with that.
Otherwise you'd be in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
What actual cox devices do you have (model numbers)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Kygord800 wrote:I have an Orbi RBK13 hooked to the router provided to us by Cox.
Most people would choose to have only a single WiFi system competing for bandwidth and channel availability.
So, yes, this forum always recommends disabling the ISP WiFi capability.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
DTC4141 Panoramic Wifi
It's a router/wife, that's all I know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@Kygord800 wrote:DTC4141 Panoramic Wifi
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Better information I found on my Cox App:
Model name: CGM4140COM
Technicolor
Revision 2.2
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Suggestions still apply for this as well.
