- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK20 disconnect when copying many files
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought the router days ago. I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time. Can anyone help? Many thanks
Dominic
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to make a backup configuration to file for safe keeping. Helps save time if a reset is needed.
Please mark your post as solved so others will know.
Enjoy.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK20 disconnect when copying many files
@dominicchengct wrote:I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time.
This is an interesting situation.
- How are the NAS connected to Orbi?
Both to the router?
Combination of router and satellite?
Wired, WiFi, or a combination? - What is the meaning of "disconnect"?
The NAS device transfers fail?
Other devices lose internet connection?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Both to the router?
Both to the satellite. If connect to router, router disconect at once.
Yes
Both r wired.
All devices connected to the wifi went disconnected. No more signal.
I think it is due to wifi lost. It transfers awhile then fails
Yes, as mentioned above
- Mark as New
- Bookmark
- Subscribe
- Permalink
@dominicchengct wrote:I bought the router days ago. I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time. Can anyone help? Many thanks
Dominic
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there, i follow your suggestions. And then try copy 3gb and 2gb from one nas to another. Both ok now. Will keep try more. Thanks a lot for yr support amd you really save me from a lot of trouble. Have a good day.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since last FW update? Might try this.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
And if you turn OFF The RBS and connect all devices to the RBR only, does the system still fail when copy files are performed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. Channel set follow yr suggestion. No help
2. I turn off th satellite. It has a nas attached. With only the router without any attached device. Seem work fine.
3. Then i attach a nas to the router. Wireless down at once
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would make contact with NG support about this. A RMA maybe needed.
