Orbi WiFi 7 RBE973
Reply
RBK50 satellite not stable
anitachan99
Initiate
I placed and setup my satellite with LED Blue light on, after several hours of usage, my mobile device disconnected with wifi with message "cannot get IP address".  Same thing happened after I reboot both router and satellite, what's wrong with setup, any advice?
Thanks
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Accepted Solutions
Guru
Re: RBK50 satellite not stable
Sounds good.
AT some point you can enable Armor and Circle. There have been some resports that Circle has been causing problems. NG seems to be aware of this issue and is working on it.
I would make a backup configuration to file for safe keeping. Saves time if a reset is needed. Then at some point, try enabling Armor or Circle and see how it goes. If you run into something after enabling those apps, You can factory reset and apply the backup confuration from file.
@anitachan99 wrote:
Thanks for your advice!
I applied your advice and it seems ok.  Let's monitor the performance for a longer period.
BTW, by applying this solution, does it mean that I cannot enable the Circle/Armor as you advised disable Circle/Armor?
Thanks .... Anita
Message 5 of 5
All Replies
Guru
Please try a factory reset and setup from scratch with the RBR and RBS.
Message 2 of 5
anitachan99
Initiate
Thanks .... Anita
Message 3 of 5
Retired_Member
Not applicable
Thanks
firmware?
Message 4 of 5
Guru
Sounds good.
Thanks .... Anita
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 914 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
