Orbi WiFi 7 RBE973
Reply
RBK50 with ex6250
ivankenzo
RBK50 with ex6250
I have RBK50 with 1 RBS50 at home, would like to extend wifi coverage on other part of the house.
I suppose to get another RBS50 but it seems quite expensive, does getting extender EX6250 AC1750 will do the job?
will it connect to RBK50 seamlesly?
Thanks
Message 1 of 4
Accepted Solutions
Guru
Re: RBK50 with ex6250
Yes you can connect a RBW or a RBS20.
Message 4 of 4
All Replies
Guru
You can try it and see if it connects. Possible it may no connect. Worth trying if you have one.
Message 2 of 4
ivankenzo
Or maybe RBW30 instead?
Any recomendation besides rbs50?
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 683 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
