Orbi WiFi 7 RBE973
Reply
RBR20 Firmware Update & Smart TV Problem
Yesterday I downloaded the latest firmware update (Router Firmware Version V2.5.1.16) and after doing the update my Samsung TV is connected to my Orbi Wireless Router / Mesh yet cannot get to the internet. Everything was fine before the update. I have rebouted my internet service, rebooted the Orbi and reset the network access on the TV all to no avail. Does anyone have a solution to this problem?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 13
Accepted Solutions
Guru
Re: RBR20 Firmware Update & Smart TV Problem
Glad that worked. Mark your thread as solved.
Enjoy.
Message 12 of 13
All Replies
Guru
Has a factory reset and setup from scratch been performed since last FW update? Try this...
Message 2 of 13
My internet service is Xfinity / Comcast and my cable modem is a Netgear Nighthawk CM1150V.
Message 3 of 13
Guru
Affter the reset,
Message 4 of 13
Do I do that via the Orbi App?
Message 5 of 13
Guru
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Message 6 of 13
Thanks will try tomorrow when I have more time.
Message 7 of 13
This is not an answer to your question.
But if, like me, you prefer an easy life that gets rid of that sort of hassle, consider using Powerline Ethernet to connect things that don't move around, like TVs.
TVs are famously bad at setting up and maintaining wifi connections. Wired is better on both fronts. It can also be faster than wifi. If you can't wire direct, Powerline is a good substitute.
Message 8 of 13
That sounds and looks simpler.
Thank-you.
Message 9 of 13
Guru
Let us know how this turns out.
Message 10 of 13
I purchased for $ 85 from best Buy:
NETGEAR - Powerline AC1200 Gigabit Ethernet Adapter (2-pack)
Model:PL1200-100PAS
SKU:4002029
It worked great and took 5 minutes set up. I was able to restore internet access to my Smart TV.
John
Message 11 of 13
Guru
Enjoy.
Message 12 of 13
Model:PL1200-100PAS
SKU:4002029
That's good. Glad I wasn't completely mad. I have never looked back since going Powerline.
There is no reason not to have PL1200 plugs, with their Gbps Ethernet, but unless it is a new smart (ho ho) TV, it will happily work with slower and cheaper 100 Mbps plugs. Streaming doesn't need Gbps. But, as I say, nothing lost.
There are a few wrinkles with Powerline, not helped by Netgear's failure to provide supporting software. No need to worry about that until you have problems. But come back if there are any.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 1665 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
