- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR40 AND DOCSIS 3.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a new Arris SB33 DOCSIS 3.1 modem connected to an Orbi RBR40 router system with 3 satellites. I suscribe to Vyvebroadband for my cable needs and I have the 1Ghz download package. My Arris modem displays 2 lights to notify the user that the modem is in DOCSIS 3.0 (green light) or DOCSIS 3.1 (blue light) mode. Vyvebroadband is swearing that the modem should be in DOCSIS 3.1 mode according to their settings but my light is GREEN and not BLUE. So my question is: Is the limiting factor from receiving DOCSIS 3.1 my Orbi RBR40 router???? There is, of course, no button on the Arris SB33 modem to manually switch between the two DOCSIS speeds, as its "automatic".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR40 AND DOCSIS 3.1
..........or is my Cable provider lying to me regarding their ability to deliver DOCSIS 3.1????
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would be the modem. You'll need to contact the Modems Mfr for additional help and support regarding there modem. Also keep in contact with your ISP. They'll need to check the signal on the lines up to the modem and check cableing.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What speeds do you get directly connected to the modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This modem has only one LED, which uses different colors to indicate status. See page 9:
I see two possibilities:
- What Arris describes as 'blue' may appear 'green' to you.
Color tests are widely available on the internet. They are quick and sort of entertaining. I found this one almost fun:
https://www.colorblindnesstest.org/ - There is a problem with your cable drop which affects some of the frequencies and the ISP is unaware of it.
Are you able to log onto the modem? (Page 15 of the manual) and navigate to page 18? That is supposed to indicate the status of the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My modem is still showing a green light indicative of DOCSIS 3.0 when it should be blue for DOCSIS 3.1. I will check my cabling for crappy splitters to rule that out as a potential communication issue.
And BTW, I passed the Color Blind Test.... LOL🤣🤣🤣🤣🤣
- Mark as New
- Bookmark
- Subscribe
- Permalink
got the rest of the data? yours only goes through channel 22 and misses the upstream and the ofmda channels
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you change something? your power levels whent form a 9 to a 4.
You do have errors in the line so it could be a line issue.
Remove any splitters, amplifiers, or signal attenuators,
Check the line for damage, kinks, old/bad/cheap connections and remove them if there are.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It might be fun to contact support and ask if this particular modem is running the correct firmware version.
I had hoped to find something on the web indicating where in the modem web interface it would display the "mode" (3.0 vs. 3.1) in addition to the front LED. No joy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My actual cable wire comes off the pole directly into my house. No "splitter" but there is one "male to male connector" to assist in extending the length of the coax to reach the modem inside the house. Guess I'll check that for moisture or something. At this point I could have saved over $200 and used my older Arris modem. 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well I changed The coax cable from the modem all the way to the drop from the pole to my house with Top shelf coax cable and used a 3Ghz male-to-male adapter to make the connection. ...... still no DOCSIS 3.1 and speeds still suck. I'm getting robbed by my ISP
- Mark as New
- Bookmark
- Subscribe
- Permalink
I fear there are now two topics being discussed:
- Is the service DOCSIS 3.1, and
- Why is the 'speed' not acceptable.
DOCSIS 3.0 provides speeds up to 1G and maxes out at 32 downstream and 8 upstream channels.
Here's one of many references:
https://kb.netgear.com/000060401/What-is-the-difference-between-DOCSIS-3-0-and-3-1
Your service consists of 32 channels of 256QAM (42.88Mb/channel) That is a total downstream speed of (24 x 42.88 = 1,029.12Mb/sec)
i.e. 1G. (as per the modem screen shot in message #9 above).
DOCSIS 3.1 modems are "Downward compatible" with DOCSIS 3.0. What appears to be happening is the ISP is delivering 1G download speed in a form that both DOCSIS 3.0 and DOCSIS 3.1 modems can handle. Did the ISP promise speed higher than 1G?
Up until this point, my impression was why the modem was not displaying the correct color LED for DOCSIS 3.1. And the answer is the color shows DOCSIS 3.0 because the channel encoding is DOCSIS 3.0.
If they had promised speeds higher than 1GB, then they would have had to use DOCSIS 3.1 encoding, and the LED would turn the correct color.
(It appears to me that) it is now time to examine "speed" rather than color.
Most of the time, we suggest that users connect a PC directly to the modem with an ethernet cable and runa Speed Test to establish "the best it can be." After that, plug in the router and test there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow Crimpon. I think I see the clear picture now. Everyone's input is GREATLY appreciated but this explains to me how my uneducated "approach" to this seems to be resolved. I'm ONLY promised MAX 1Ghz so your explanation has enlighten me tremendously. Now to address the speeds.
I check my speed via my ORBI internet connectionto my modem I will directly connect a PC to the modem and see if there's a difference. I'll report back Thanks! !
