Orbi WiFi 7 RBE973
Reply
RBR40 stopped working with Wi-Fi calling
MMSOOD
Follower
I have Google Fi phone service and use wi-fi calling when at home. In fact, I use wifi for everything on that phone while at home.
Text works ok
Data works ok
Incoming call work ok
Outgoing calls cannot be completed with using my home (orbi) network
If I take my phone (pixel 3a xl) to the local coffee shop and use their wi-fi, then outgoing calls work also.
I have done some troublehsooting using information on here but nothing has worked so far
  • I have turned off daisy-chain tol;ogy
  • I have disabled SIP ALG
Any help would be appreciated
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Guru
Re: RBR40 stopped working with Wi-Fi calling
Try enabling Beamforming, SIP ALG, and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 4
Blanca_O
NETGEAR Moderator
Hi @MMSOOD
If you have Disney Circle enabled, kindly disable it, test WiFi calling and let us know the result.
Blanca
Community Team
Message 3 of 4
Blanca_O
NETGEAR Moderator
Hi @MMSOOD
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 667 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
