Orbi WiFi 7 RBE973
Reply
RBR50 Has Slow Wired speeds [SOLVED}
togar
Follower
I did a bunch of searches for this issue. Most of the responses were pretty convoluted so I wanted to elevate a solution that worked instantly for me. Changing this setting gave me the same speed through the Orbi as I got directly connected to the fiber optics.
The Issue:
Wired connections to the Orbi were seeing speeds half as fast as they should be. This was in both up and down transfers.
The Solution:
To fix this problem, you need to turn off Daisy-Chain Topology. To turn off this “feature,” login to the router and navigate to: Advanced > Advanced Setup > Wireless. Then uncheck the Enable Daisy-Chain Topology option. This will cause the Orbi to reboot. I can’t explain why a wireless setting messes with the wired speeds, but it does.
After reboot, my wired speeds went from 225 Mbps to 570 Mbps.
I hope this works for you too. Enjoy! Smiley LOL
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: RBR50 Has Slow Wired speeds [SOLVED}
Daisy Chain can be disabled if there is only 1 RBS connected to the RBR or if there is a RBR alone and no RBS being used.
Thanks for sharing. Smiley Wink
Enjoy.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1334 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
