- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50/RBS50 Issues with Nest Cameras
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had my Orbi system working perfectly with my Nest Cameras - but recently the router failed and had a new one sent to replace it.
The internet is super fast - and not having trouble streaming video - but my Nest Cameras are offline more than online.
Nest tells me that I should split the 2.4 from the 5 - which I supposedly can't do - and would be a pain for many other reasons as well...
I've been on the phone with Orbi and changed multiple settings with no improvment.
Any suggestions would be appreciated.
Currently running most recent firmware. Have 2 regular satelittes and 1 outdoor.
The 2 indoor satelittes have ethernet (wired) backhaul.
Thanks much!
signed - FRUSTRATED
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50/RBS50 Issues with Nest Cameras
@moraru wrote:Nest tells me that I should split the 2.4 from the 5 - which I supposedly can't do - and would be a pain for many other reasons as well...
The advice from Nest seems illogical. These Nest cameras functioned correctly with an Orbi router for some time without "splitting" the SSID's. Ergo: this is not necessary.
I always look for "what has changed?" The router was replaced with the same model. How was the "swap" accomplished? Had the original configuration file been saved to disk and than was copied onto the new router, or was the new router "set up from scratch"?
How were the original satellites synched with the new router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Correct - it worked well with the Nestcams earlier.
Unfortunately I did not save the original configuration file from the original Orbi.
I set up the new orbi as a new router "from scratch" and connected the satellites during the initial setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you give the new router exactly the same SSID and password as the first router?
All devices should have connected automatically.
Since the new router may have been broadcasting before the satellites were synced to it, maybe the Nest cams all connected to the router? Can you restart the Nest cams and see which Orbi they connect to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Actually no. I live in an isolated area - so previously didn't have the internet password protected. I've now added a password - so had to individually re-add all the nests to the wifi network. They are all connected to the closest satelittle/router
@CrimpOn wrote:Did you give the new router exactly the same SSID and password as the first router?
