Orbi WiFi 7 RBE973
Reply
RBS 50 Satellite "stuck" on firmware 2.0.0.74
Dave61
I have just added a second satelllite to my home network. As delivered it was on firmware v1. Via the admin panel I did a firmware update to v2, however I notice that whilst the router and first satelllite are on v2.1.1.16 but the new router is v2.0.0.74 with "No new firmware version available" listed.
Screen Shot 2017-12-28 at 13.40.46.pngDoes this mean that there is no future update path for this particular router?
Message 1 of 9
Accepted Solutions
aaz
Virtuoso
Virtuoso
Re: RBS 50 Satellite "stuck" on firmware 2.0.0.74
You need to unzip the file and then load the RBS50-V2.1.1.16.img file.
Message 8 of 9
All Replies
mahughesnh
Guide
When my router updated to the latest firmware, the satelite did not update.  I did the update manually and it was fine.  Not sure why it didn't update automatically, it always has with past updates.  But it was not a big deal to do it manually.  Just follow the instructions in the advanced screen of the router interface and it took about 5 minutes to complete and link up.
Message 2 of 9
Dave61
Thanks, manual update was a good idea, but I get an error: "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
I downloaded the file and tried again, with the same result.
Message 3 of 9
DarrenM
Sr. NETGEAR Moderator
Try to power cycle that satellite unit then try the update again.
DarrenM
Message 4 of 9
mahughesnh
Guide
Make sure you download the firmware for the RBS50, not the RBR50.  Easy mistake to make.
Message 5 of 9
Dave61
Thanks, just tried that but still same error.
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 6 of 9
Dave61
Thanks, double checked. Unless Netgear are mislabelling files it is definitely the RBS version.
Message 7 of 9
aaz
Virtuoso
Virtuoso
Message 8 of 9
Dave61
Thanks.
That doesn't explain why the system said that there was no update available, but hey ho.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2241 views
  • 4 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
