Orbi WiFi 7 RBE973
Reply
RBS50 Firmware Update via iOS app
Madock
Follower
Do I remember correctly that Orbi RBS50 Satellite firmware could be updated via the iOS app? As I try today, I only find an ability to update the RBR50 Router.
Thanks in advance for any available assistance.
Message 1 of 2
Guru
Re: RBS50 Firmware Update via iOS app
If it's not appearing that you can use the iOS to update the satellite, it's recommended to use a PC and manually update the satellite first, the update the router. Recommend using a wired LAN cable connected PC. If the satellite is already connected to the ruoter, you can wire LAN cable connect to the back of the satellite and log in to the satellite and update it there if you have already downloaded the FW update files.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 779 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
