- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS50 dropping internet connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
A few days ago, my satellite really started disconneting from the internet. I applied the 2.1.1.16 update, and it isn't helping. I can see everything on my internal network, but the satellite can't route the the internet. This is getting annoying, as I have to rest the satellite every 1-2 hours.
I either need this fixed, or need a way to lock wifi clients to the router, and just use the satellite box for the ethernet. Can someone help here? I don't want to have to go with another solution, as I like not having to have a persistent connection to a backend like mesh systems have.
It's almost like the satellite loses the default route.
Anecdotally, this seems to trigger more if I have a long-running data transfer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 dropping internet connectivity
irrespective of model it appears that this issue is common to many netgear products - they have a built in obsolence that means they fail after a few months - check out the posts here
https://www.consumeraffairs.com/home_electronics/netgear.html
Netgear programme their routers to fail so that they can charge between 150 and 50 dollars for a 'fix' that means you get one off product support.
i am still seraching online to figure out how to fix my router - it is a settings issue but they still want more than the cost of the router to tell me how to get it to work
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, it's just that they don't know what they are doing. Nothing malicious - just plain old stupidity!
