Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbr50 speeds dropped drastically
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-06-08
11:59 PM
2020-06-08
11:59 PM
My speeds on the ORBI RBR50 just dropped from 500 Mbps to 1.75 Mbps. I did the update, I have reset the modem, I have unplugged the router for awhile. Nothing seems to work to get my speeds back up. Any suggestions.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-06-09
08:49 AM
2020-06-09
08:49 AM
Re: Rbr50 speeds dropped drastically
Have you powered OFF the ISP modem AND RBR for 1 minute then back on?
Be sure to test speeds on a wire connected PC.
If anything, try a factory test on the RBR and setup from scratch. Be sure to not enable Access Controls, Armor, Circle, QoS speed test or Traffic meter. Use Ooklas installable speed test app and run a speed test as soon as the setup wizard is finished.
Message 2 of 2
Announcements
