Orbi WiFi 7 RBE973
Reply
Rbr50
ChinoMorales
Tutor
Rbr50
I'm using Orbi RBR50, router with two satellites and we are changing our internet provider, do I have to do a "New Setup" once I have the new provider? I will be using same modem though.
Thanks a lot.
Message 1 of 6
Accepted Solutions
Guru
Re: Rbr50
Just power OFF the modem when you change ISPs for 1 minute then back on.
Thanks a lot.
Message 3 of 6
All Replies
Guru
Re: Rbr50
Thoretically no.  I would recommend it however. It might work great once the new ISP provisions your modem but it might have issues. Just take a backup of your configuration so you can restore it once you've got the new setup provisioned.
Message 2 of 6
Guru
Re: Rbr50
Thanks a lot.
Message 3 of 6
Re: Rbr50
... and while you are doing that, also turn off the Orbit router and then turn that back on when the modem is up and connected.
Message 4 of 6
ChinoMorales
Tutor
Re: Rbr50
Thanks a lot for your help.
Message 5 of 6
ChinoMorales
Tutor
Re: Rbr50
I waited for the new ISP tomsend the signal to my modem as did as suggested by you, all working fine now, thanks again.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1341 views
  • 4 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
