Orbi WiFi 7 RBE973
Reply
Rbr50
Dobyhawaii
Tutor
Rbr50
How do I get update if app is having trouble detecting if new update is available. I checked internet and there is an update available.
Can I download update to my phone and send to modem using app?
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 8
Accepted Solutions
Retired_Member
Not applicable
Re: Rbr50
Don't worry about FW updates.  NG will push critical updates to you automatically.
Message 2 of 8
All Replies
Retired_Member
Not applicable
Re: Rbr50
Message 2 of 8
Guru
Re: Rbr50
If you want too, you can use a PC or laptop to download FW updates. Download the FW updates from here:
https://www.netgear.com/support/product/RBK50.aspx#download
Use a web browser to apply the FW udpate to the RBR.
For any Orbi app help and information, please post here in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
Message 3 of 8
Dobyhawaii
Tutor
Re: Rbr50
Thank you! 🙏👍😊
Message 4 of 8
Dobyhawaii
Tutor
Re: Rbr50
Thank you!
Message 5 of 8
Retired_Member
Not applicable
Re: Rbr50
@Dobyhawaii wrote:
Thank you!
Aloha
Message 6 of 8
Guru
Re: Rbr50
Enjoy. Smiley Wink
@Dobyhawaii wrote:
Thank you! 🙏👍😊
Message 7 of 8
Retired_Member
Not applicable
Re: Rbr50
@FURRYe38 wrote:
Enjoy. Smiley Wink
@Dobyhawaii wrote:
Thank you! 🙏👍😊
They will....by staying away from manual updates.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1120 views
  • 5 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
