- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Re-assigning mac address keeps disrupting wired speaker
- Mark as New
- Bookmark
- Subscribe
- Permalink
Goodmorning,
At irregular times my KEF LS50 Wirelsess speakers lose connection. They are wired to the RBR50-sattelite.
Now I noticed that the loss of connection coincides with the log beneath: 192.168.1.10 is assigned (fixed) to my speaker. For no reason at all connection is broken exactly on the times when this happens. It happens in periods of 2-3 hours in a row, with irregular intervals. And during the week maybe one or two days this happens.
[DHCP IP: 192.168.1.10] to MAC address 84:17:15:00:b8:bd, Sunday, November 17, 2019 10:11:18
[admin login] from source 192.168.1.4, Sunday, November 17, 2019 09:55:54
[DHCP IP: 192.168.1.4] to MAC address 04:0c:ce:d9:04:16, Sunday, November 17, 2019 09:54:07
[DHCP IP: 192.168.1.10] to MAC address 84:17:15:00:b8:bd, Sunday, November 17, 2019 09:54:00
[DHCP IP: 192.168.1.16] to MAC address 80:82:23:15:df:6e, Sunday, November 17, 2019 09:39:55
[DHCP IP: 192.168.1.10] to MAC address 84:17:15:00:b8:bd, Sunday, November 17, 2019 09:28:44
[DHCP IP: 192.168.1.12] to MAC address 08:02:8e:8d:b7:5b, Sunday, November 17, 2019 09:25:09
[admin login] from source 192.168.1.4, Sunday, November 17, 2019 09:13:08
[DHCP IP: 192.168.1.10] to MAC address 84:17:15:00:b8:bd, Sunday, November 17, 2019 09:12:20
I am not an in-depth technical guy so I hope someone has a simple solution to fix this?
Thanks in advance!
René
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Re-assigning mac address keeps disrupting wired speaker
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the speaker drop out when connected with WiFi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I dont know. Found a lot of related problems with DHCP re-assignments but no solutions. I think I will contact the helpdesk directly to sort this out. Dont want to start old discussions again on this forum. But if I get the solution, I will share it immediately. Thanks for thinking with me!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you set up a IP address reservation for the RBS and your speaker device ON the RBR? No static IPs on the speaker device. Should use auto IP address assignment here.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@ReneK wrote:I dont know. Found a lot of related problems with DHCP re-assignments but no solutions. I think I will contact the helpdesk directly to sort this out. Dont want to start old discussions again on this forum. But if I get the solution, I will share it immediately. Thanks for thinking with me!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried all the options as @FURRYe38 described. Some changes caused slow traffic, more wifi disconnections etc. The only thing that is switched off now is the 20/40Mhz option. But the big problem was my modem that still provided a WLAN signal. No SSID, but still transmitting. That interfered with the Orbi. Thanks for thinking with me and the solutions offered!
Kind regards,
René
- Mark as New
- Bookmark
- Subscribe
- Permalink
Need to get the wifi radios disabled ont them modem if possible.
