Orbi WiFi 7 RBE973
Reply
Satalite won't connect after I followed all you posted. RBR50
Loulabell
I read the message board that was running here. I've tried everything that was mentioned. I still can't get my satalite orbi to connect. I'm getting real tired of this.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 11
Guru
Re: Satalite won't connect after I followed all you posted. RBR50
Was the FW updated on the RBR before the RBS?
Message 2 of 11
Loulabell
I’m not sure on what you’re asking. I can tell you that it worked like a champ for a year. It updated itself and now the satellite can’t be found. And the main unit is dropping all the time. And only letting some things happen. I also saw it stated it was a 40 not a 50. The photo shows it.
Message 3 of 11
Guru
Try a factory reset on the RBS and then press the sync button on the RBR then RBS and see if it will be re-added. Do this while in the same room as the RBR.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Message 4 of 11
Loulabell
I’m not currently near it. But I did do the factory reset and the entire house area is around 2k sq ft. The satellite was down a hall from the router. Approximately 25-30 feet with 3 walls in between. Like I said. Never had an issue before this recent update. The modem is an Arris. I put the model number on here last message. I don’t remember and it’s not letting me look. I know my internet speed is 200. The firmware is 2.3.1.60
Message 5 of 11
Loulabell
Oh and right now they’re sitting 5 feet from each other and can’t seem to connect
Message 6 of 11
Guru
Can you reset the RBS and connect a wired PC to the back of the RBS. Wait for a few minutes then your PC will get an IP address from the RBS. Open a web browser and navigate to 192.168.1.250 and you should be presented with the RBSs web page. Log in as admin and PW is password. Verify the FW version is the same as the RBR. If you can't seem to log in or get to the RBS web page, possible the RBS maybe faulty...
Message 7 of 11
Loulabell
Sorry that took so long. I had to go buy another Ethernet cable. I tried the IP address. It didn’t work. Every time I try to access somewhere; the new ‘security’ blocks it. I’m really ready to try something new. I pushed reset, the power light held then flashed a few times. I run all macs not PC. It’s new security even blocks photos on my texts, emails, when I tried to access these login pages.
Message 8 of 11
Guru
You may need to temporarily disable your security program then.
Message 9 of 11
Loulabell
Ok finally got the security disabled. Still can’t access the website. Sorry but you’re the k my one who answers.
Message 10 of 11
Guru
I  would contact NG support and see if there is a problem with the satellite:
https://www.netgear.com/mynetgear/registration/login.aspx
@Blanca_O
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1439 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
