Orbi WiFi 7 RBE973
Reply
Satellite Connection
sbrldahl
Question for all;
Is the SRS60 satellite (Firmware Version: V2.1.4.16)
compatible with the RBR50?
Cannot get the satellite to connect to the RBR50 Router (Firmware Version: V2.1.4.16)
Thank you in advance for your help...
Lars
Message 1 of 4
Guru
Re: Satellite Connection
@sbrldahl wrote:
Is the SRS60 satellite compatible with the RBR50?
No.  The SRS60 is for Orbi Pro systems, the RBR50 is Orbi (not Orbi Pro).
Message 2 of 4
sbrldahl
Thank you!
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 859 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
