Orbi WiFi 7 RBE973
Reply
Satellite connection status
msfox99
Guide
Hi.  I have had the RBK50 for a while, and also have a 2nd satellite.  (RBS40)  Recently, around the time I updated to the latest firmware, neither the web admin page, nor the Android app, show the satellites as being connects.  That is, it says, 0 satellites.  But when I power down and up a satellite, it shows the blue light when done starting up, indcating a good backhaul connection.  And the devices near the satellites seem to have a very strong signal.  The satellites used to show as being active always.  I have gone through the sync process.
The current firmware on the base router is V2.5.0.38.
Any ideas!  Thanks.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 12
Accepted Solutions
Guru
Re: Satellite connection status
Try a Generate backhaul password for the RBS under Advanced/Advanced settings/Wireless settings. See if this helps. If not, A reset will be needed on the RBR and RBS setup from scratch.
Message 4 of 12
All Replies
Guru
Did you power OFF the RBR and RBS as well?
Message 2 of 12
msfox99
Guide
They are around 30-40 feet.  Everything has worked fine for the last year plus.  I did power cycle everything.
I haven't done a factory reset yet, and would prefer to avoid that for now.
Message 3 of 12
Guru
Message 4 of 12
msfox99
Guide
I think I will  go ahead and do a factory reset tomorrow.  I assume that I only need to reset the router,   not the satellites?
Thanks for your help.
Message 5 of 12
Guru
Ok.
Message 6 of 12
Retired_Member
Not applicable
There's your problem:   V2.5.0.38.
How did you come upon this?
Any ideas!  Thanks.
Message 7 of 12
msfox99
Guide
That is the current latest version.    I clicked Update Firmware on the web interface, and it did the update.  What are you saying VAJim?
Message 8 of 12
Retired_Member
Not applicable
IF your system was working fine before the update....why update?
Message 9 of 12
Guru
Let us know if a factory reset and setup from scratch helps your system. I manually loaded v38 FW and factory reset and setup from scratch. No issues with satellite connections, wired or wireless.
Message 10 of 12
msfox99
Guide
Yes, after I did a factory reset and re-set up the router, everything seems to working fine.  Both satellites are now listed as well as all other attached devices.
Thanks again for your help.
Message 11 of 12
Guru
Good to hear. Glad it's working. Please mark your thread as solved so others will know.
Enjoy. Smiley Wink
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 3082 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
