Orbi WiFi 7 RBE973
Reply
Satellites keep dropping off line
HCC202
Star
My system has been stable for several months now all of sudden I keep dropping the satellites. My system is RBR 50 and my firmware is 2.2.1.210
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: Satellites keep dropping off line
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 566 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
