Orbi WiFi 7 RBE973
Reply
Second Orbi Satellite no connecting
TDN
Follower
Follower
Hi,
I have the Orbi RB50 router and satellite running successful for some time, I decided to add another satellite to help with wifi reception upstairs. I bought a single RBS50 unit, connected it to the system, on the web GNU it showed up and said system needed a firmware upgrade, I did as asked and since then only the 2 previous units upgraded and connected, the new satellite just sits in the corner flashing its white light and won't connect.
I have tried factory resetting
Tried powering everything off and on
Tried connecting to it via ethernet but it has no ip and I can't log into it to perform a manual firmware upgrade
pretty frustrated at this point!
Tuan
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Second Orbi Satellite no connecting
You should contact support at this point.
http://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 639 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
