- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Setting a different range of IP addresses
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm about to set up my Orbi system, but the standard range of IP addresses is going to cause me much work. The router I currently use assigns IP addresses in the range 192.168.254.xxx, while the Orbi uses 192.168.1.xxx. About half my equipment uses static IP addresses, and if I use the Orbi range, I will have to go in manually to each of them and change the address. I'll also have to modify some applications that use those devices, to allow them to be "found".
Can I set Orbi to use (all but one of) the range of IP addresses that my existing router assigns, instead of its standard set? The one exception would be the address of the modem/router currently in use. If yes, any tips on doing that efficiently? I need about 20 static IP addresses, and another slightly smaller bunch that can be DHCP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Setting a different range of IP addresses
The Orbi router when used in Router mode and as a DHCP server has pretty much the standard controls for address assignment. You can set the range for what DHCP will use as well as assign IP addresses to specific devices. It is all on the Advanced.. Setup.. Lan Setup.. tab.
- Mark as New
- Bookmark
- Subscribe
- Permalink
UPDATE: Nevermind, found it. Ignore this post (I would delete it but there doesn't appear to be a way to do that).
I have the latest firmware (V2.1.4.16), but there is no "Lan Setup" on the Advanced setup page, so there appears to be no way to set the DHCP range. Anybody else seeing this? Am I missing something??
-Fred
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is LAN setup under Advanced Tab...
Glad you found it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I ran into the same issue when I initially set the system up. I think I forgot to check the box that set the Orbi as a DHCP server, but once the box was checked I was able to see the DHCP address range option.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Instead of settling “static” IP address in each device, Wouldn’t you be better off “reserving” the IP address against each device’s MAC address? This is what I do. Then each time I need to rebuild my network (old devices are removed, new one added,etc) you just go into the reserve table reserve each address again, restart/reboot each device & then should then be re-assigned the new IP address
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can and is recommended. However there are some devices that you can set for static IP ON the devices, devices with little need of router management, internet and use. Devices like printers, controllers, NAS and Cameras are good candidates for Static IP. This frees up router resources as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
On the Advanced Tab, select "Setup", and "LAN Setup" is one of the choices under it.
